Good crank or bad
Old Jun 12, 2011 | 01:17 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Good crank or bad
Since #1 rod bearing spun I have a nice lip on the journal where the rod dug in. The crank rod journals had been cut .010 before. I'm getting a reading of 2.490 where #2 rod was and 2.4688 where #1 was at the lowest point. Now since the lip or raised area is maybe 180 degrees or half way around the journal and the difference is .0212, .0424 would have to be taken off to make the journal round again. Now .0424 plus the .010 equals .0524 and .040 is the limit I believe so if I did this correct, it also equals I'm out of luck.
Is the limit .040 and am I correct in my assumption? Thanks.
Old Jun 12, 2011 | 03:05 PM
jpaulwhite's Avatar
Yes
Old Jun 12, 2011 | 06:17 PM
Navy P-3 FE (Ret.)
Thanks. A good crankshaft wasted over a couple thousands of an inch. I shouldn't have used the term "out of luck", I do have a virgin 455 crankshaft to use.
Old Jun 12, 2011 | 06:53 PM
cutlassefi's Avatar
But have it checked they usually run big. Shoot for around .0025 clearance on the rods.
Old Jun 12, 2011 | 07:16 PM
Navy P-3 FE (Ret.)
Will do. The crank needs a little work anyway, won't be worked on until next year most likely. I packed my engine pieces away in rubber maid containers and brought to the basement. Funs over for this year
Old Jun 13, 2011 | 10:17 PM
64Rocket's Avatar
A good crank shop can weld up the bad spot and machine it again to .010 again.
Gene
Old Jun 14, 2011 | 04:42 AM
507OLDS's Avatar
It still has some potential for a BBC rod,and some additional stroke.
Old Jun 14, 2011 | 03:51 PM
Navy P-3 FE (Ret.)
I guess I have options and for money purposes I'll use my other crankshaft and hold on to the bad one just in case.
Bernhard
Nov 24, 2022 09:12 AM
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
torquemonster
Dec 2, 2006 04:39 PM
