3.8 v6 to 350 v8 smog problems
I have a 84 cutlass supreme v6 i want to do a 350 swap. I live in california and i was told that my car wouldn't pass smog if i swapped the motor. I was wondering what is need to get the v8 to pass smog in california.
The laws in Calif allow you to swap any engine that's the same year or newer, so long as you also swap ALL the emissions equipment that goes with the newer engine. Bottom line is that you can swap a cleaner engine, but not a dirtier one. You also are restricted to engines from the same emissions class. In other words you cannot swap a truck engine into a car since trucks have a less stringent emissions standard than cars. Simply tacking converters onto a random engine will NOT pass Calif emissions. Also, for a non-stock swap, expect to have to go to a referee station to verify the year of the new engine and the appropriate equipment.
I did that swap on my 77 and it passed emissions and got better fuel economy. The 350 was out of a 74 Salon. Gotta Luv CA...
Not only does the engine have to be the same year or newer, but ALL of the emission equipment from the donor vehicle must be installed CORRECTLY and functioning properly when you take it to the ref. They will be going over the car with a fine toothed comb so be prepared with some butt lube, because they won't bring any.
Kids today are spoiled, and so are their darn lungs!
Yes, one can certainly camouflage any larger Olds motor to look like a 307 in the G-body cars, and if everything is hooked up, it's likely that even a 455 can be snuck past most emissions techs. Such an installation will NOT be legal, since those motors were never certified for the years in question, but in practical use you can get it by.
Well, I survived just fine [cough], and I can remember the yellowish haze over the City, and the smell of eight lanes of 1960's-era traffic backed up on the NJ Turnpike as far as the eye could see on a 98 degree day.
once they discover the extra two cylinders aren't they going to want to run the numbers on the block to determine the year? If he was starting with a v8 car then it might be possible (though not legal).
years ago when MN was doing emissions testing, my cousin swapped a 350 in to his 87 Monte SS. he did use a 350 that was newer than the car, but due to some vagueness with the ability to pin an exact year on the block he wasn't able to get it passed properly. He ended up getting a 1 year exemption and then selling the car before the tabs came due again.
Yeah, that's certainly a risk. Again, the OP didn't respond if he was talking about an Olds 350 or a "Type C" motor. Sadly, the latter WOULD be legal if the proper year motor was used.
2blu442
February 24th, 2008 07:07 AM
