260 2bbl
Old Mar 6, 2007 | 05:06 PM
terribleonexx88's Avatar
260 2bbl
how can i put an air cleaner made for a 4bbl on my 2bbl carb
Old Mar 6, 2007 | 05:14 PM
American Lead's Avatar
2Blue 55
I am unsure if you can do this unless the air horn is the same size, but if you really wanted to you could rig up some sort of adaptor to fit the bottom of the air cleaner or the top of the air horn. Good luck and let me know how it goes.
Old Mar 6, 2007 | 06:55 PM
OldsMotion's Avatar
OldsMotion
in other words, you can't.
Old Mar 6, 2007 | 06:58 PM
crazy'boutOlds's Avatar
Hold on now. My 260 had a dual jet that looked like a four barrel. The air cleaner from my 260 two barrel fits on my 403 four barrel. I could sell you a rebuilt carb from my 260 and your four barrel air cleaner with fit!
Old Mar 6, 2007 | 07:19 PM
i found this and i think it might work... http://www.partsamerica.com/ProductD...artnumber=6400
Old Mar 6, 2007 | 07:22 PM
how good are the 260ci's any way it feels like my 87 4cyl cavalier has more ***** than my 78 cutlass that i just bought.
Old Mar 6, 2007 | 08:22 PM
I know what you mean. My 76 Cutlass S four door has one with under 50,000 miles. I sure don't try to pass.
Old Mar 7, 2007 | 02:39 PM
2Blue 55
I suppoze if the air horn was the same size you could use a r bbl air cleaner on it without a mod... I don't know if it would make any difference in punch from stop or anything if that is what you are looking for. Can you post up some pics so we can see what it is.
Old Mar 9, 2007 | 07:16 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. The 260 was made for smooth v8 performance, but mainly fuel economy. In 1978 technology. Less gas, less power. As for your cavalier, if your 260 had the same electronics hooked up, WOW. But you can still make a killer stroker out of a 260. Same block as the 350, 403. Read more of the forums. Find a 4 bbl intake and carb from a 350, bolt it on to your 260. the breather will fit, and your Cavalier might stay parked. It'd be a good start. Hope this helps. Jim.
xbody
Sep 18, 2020 09:03 AM
boese1978
Apr 23, 2012 07:46 AM
OldsMotion
Sep 17, 2009 09:42 PM
67htc
Jul 22, 2007 07:41 AM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
