1990 Cutlass Ciera engine question
All I know about this engine is that it is a V6. My question is about the serpentine belt. does this belt run the camshaft as well? should it break do I have to worry about timing? How do I check it for wear and when do I need to replace it?
Car seems to run strong. Over 200K and still going strong.
Then you have a 3300 a very good engine, I use to own a 90 Buick Century that had a 3300. I remember getting around 25-28 mpg with it. The fuel injection system on this engine is simple, and easy to work on and very dependable. I would suggest getting a service manual if you plan on doing your own repairs.
The engine itself is really clean. Previous owner must have really taken the time to care for the engine. Somehow I would still feel better with a carburetor. Anyone know if the AC system uses the old coolant or new? I need to have it recharged.
The 3300 and the 3800 did have a nylon cam gear. They are an interference engine. They are a great motor but will wipe out the valves if the cam gear comes apart. At 200k miles I would think about having it done. Especially if you are planning on keeping the car.
Yes, same principal as the v8, just a little tighter quarters since it is transverse. Parts and labor I would ball park it around $5 bones. Pm me if you want a closer estimate. I'll look it up for you at the shop tomorrow.
