1986 Cutlass Supreme 3.8L - what is this connector?
Old Sep 23, 2023 | 10:28 AM
WKU1990's Avatar
While working on my wife's 1986 Oldsmobile Cutlass Supreme 3.8L V6, I saw this connector hanging loose. I didn't see anything that had an "open" connector and at this point I have NO idea what it goes to. Any ideas anyone?
Old Sep 23, 2023 | 10:36 AM
Sugar Bear's Avatar
Connection to measure the duty cycle of the mixture control solenoid in the carburetor. A test connection, it should be blank.
Old Sep 23, 2023 | 11:58 AM
This is why it pays to purchase and read the factory Chassis Service Manual. Your car uses a computer-controlled carb and distributor. The computer controls a solenoid inside the carb that pulses to adjust the air/fuel ratio to match the needs of the engine as you drive. That green test connector allows you to connect a dwellmeter (on the six cylinder setting) to monitor the duty cycle of this pulsed solenoid. You then turn the idle mixture screws to achieve the required duty cycle at idle. You cannot tune these carbs with a vacuum gauge the way you can on non-computer controlled systems. Failure to follow the factory adjustment process will guarantee that the car runs poorly.
Old Sep 23, 2023 | 12:54 PM
WKU1990's Avatar
Once again, you guys are a WEALTH of KNOWLEDGE! Thank you everyone for the replies. I do appreciate the education.
pipewelder69
Jul 4, 2021 07:06 AM
jaunty75
Jun 4, 2020 08:28 PM
California
Apr 20, 2020 04:58 PM
caddy
May 16, 2014 09:31 AM
72droptop
Jul 27, 2007 07:52 PM
