1972 cutlass 350 oil pan
Old Nov 13, 2025 | 02:54 PM
Gensue's Avatar
Hello all can you remove the oil pan with the engine still in the car?
Old Nov 13, 2025 | 04:06 PM
v8al's Avatar
Registered Olds Owner
Yes, kind of. You will still need to disconnect the motor mounts and raise the engine.
A google search will fill you in. site:classicoldsmobile.com 1972 cutlass remove oil pan in car
Oil pan removal
need some help replacing the oil pan gasket
Lifting engine to replace oil pan gasket
455 oil pan gasket replacement.
Old Nov 14, 2025 | 05:44 AM
Yes, it's possible. You have to rotate the crank to a specific angle to clear the counterweights. You have to raise the engine a lot. By the time you get to that point, you are about six bellhousing bolts away from just pulling the engine out, which is MUCH easier to work on than under the car with oil dripping in your face.
friesjh
Aug 15, 2018 11:40 AM
GraciaLee
Non-Olds Engines
Mar 12, 2015 02:49 PM
code26
Dec 30, 2014 06:22 PM
dnmfranco
Oct 31, 2013 12:40 PM
ihengineer76
Oct 16, 2012 06:17 PM
