1970 cutlass motor 350ci
Old Sep 6, 2007 | 12:27 PM
shaks 442 clone's Avatar
what year 400ci motors crank will fit in a 1970 olds 350 ?
are they the same engine family ?
or is a 383ci olds not possible ?
Old Sep 6, 2007 | 03:36 PM
88 coupe's Avatar
Junior Member
Originally Posted by shaks 442 clone
what year 400ci motors crank will fit in a 1970 olds 350? ........
Doesn't matter what year it is, a 350 is a 350.
Neither one is a direct bolt in, because the main journals are larger. Same reason a Chev 400 crank will not a bolt into a Chev 350 without grinding the mains down.
With your stock bore, an early 400 crank would make it 412 CI, and a late one would take it to 440 CI. If it was worth the effort, it would already be common practice, and you would not have asked the question.
........ are they the same engine family? ........
Yes. Same block, just different deck heights and crank journal sizes.
........ is a 383ci olds not possible ?
More than possible. Any competent engine builder can handle it. It is what they do.
Question is, why?
Norm
Old Mar 10, 2012 | 05:18 PM
Octania's Avatar
Smile
That sounds like Chevy talk
If you want to get into that kind of voodoo you may wish to use the 350 Diesel block, which has BB sized main bearings. Have your 425 crank cut to use your Chevy rods, and custom pistons.
Others have done this with good success. $$$$$ though.
A less expensive alternative would be a 403 with a forged 330 crank and pre-73 SBO heads. Cubes and a strong crank.
Be sure to use a halo girdle
http://www.ebay.com/itm/Oldsmobile-M...3f4849&vxp=mtr
Old Mar 10, 2012 | 05:27 PM
Vega's Avatar
Agreed with Octania, if youre looking for more cubes a 403 or 455 would be your best bet. Which one is your call depending on what youre looking for, 403s have massive bore and short stroke (4.351x3.385) and 455s are the exact opposite with smaller bore and massive stroke (4.125x4.25). Both have their weaknesses, 403s have weak mains and 455s have oiling issues, both have fairly easy cures. The 403 is essentially a 350 bored way way out
Old Mar 11, 2012 | 05:35 AM
380 Racer's Avatar
Another 4 yr old thread?
Old Mar 11, 2012 | 07:14 AM
Octania, what gives? You've done this at least three times in the past month or so.
Old Mar 11, 2012 | 08:27 AM
coppercutlass's Avatar
Chevy budget Olds powered
must be bored lol.
jpc647
Apr 16, 2012 08:00 AM
spate51
Mar 10, 2012 05:11 PM
MDchanic
Dec 12, 2010 07:53 PM
sixty9olds
Aug 26, 2009 11:49 AM
Wasted
May 11, 2008 01:41 AM
