1970 CUTLASS, BACKFIRING 350 ENGINE
Old August 27th, 2007, 04:49 PM
shaks 442 clone's Avatar
just 3 nights ago out of the blue my car started backfiring im baffled
i did a vacuum test off of the carb it was normal not flickering beyond normal
the car has an msd 6a box, upgraded ignition to h.e.i, stock intake, edelbrock carb 600cfm, it has a mechanical fuel pump and a piggyback electric one by the tank (it came like that when i bought it)
any help with things i should check to help get down to the root of the problem would be really appreciated
also one last thing what should the timing of a 1970 350 olds engine be set at?
thanks
~shak
shaks 442 clone is offline
Old August 27th, 2007, 06:34 PM
$tryker's Avatar
Timing should be 10 or 14 degrees, depending on the horse power you have. Although you could squeeze a couple more degrees with the HEI.
You didn't state the location of the backfire. Was it a pop through the carb, or in the exhaust. Check the timing first. An exhaust backfire could even be air entering the exhaust system. Let us know how things are going.
$tryker is offline
Old August 27th, 2007, 11:20 PM
well it pops in both the carb and the exit of the exhaust
and also to add not sure if its important but the filler neck on my gas tank is damaged when i step on it gas pours out no matter how tight the cap is
so i purchased a chevelle gas tank today i decided to put the chevelle gas tanks cap on my cutlass and the backfiring seem to have gotten worse
could the filler neck be my problem
the only thing i dont understand is the filler neck has been like that for a year now and this just started like 4 days ago
hope someone can lead me in the direction of the anwser
Old August 28th, 2007, 06:13 AM
Senior Moment
Jokers69's Avatar
does it run well enough to drive it?
does it cough through the carb once or twice when throttling up then smooth out?
if your cruising and whack the throttle like your passing what happens?
under what conditions does it backfire through the exaust?
Jokers69 is offline
Old August 28th, 2007, 07:24 AM
yes it runs well enough to drive i drive the car everyday even thto it is backfiring, also is that bad for the car ?
it does bacfire through the carb when i really wanna get on it, so i have to slowly move up in speed instead of just gunning it and gaining speed the fast way
if i gun it like i said the backfiring will get worse it will backfire out of the carb, i will have the loss of power feeling like the car dies out for a second then comes back and then dies out again
when i am coasting on the freeway at like 60ish thats when i was having the most exhaust backfires
Old August 28th, 2007, 09:06 AM
Senior Moment
Jokers69's Avatar
try disconnecting the vacuum advance where it goes into the carb AND PLUG it off AT THE CARB. Drive it and see if that makes any changes. If not hook it back up.
This might sound like a silly question, but did you put gas in it around the time this started happening? If so, it may have picked up some water, pour in a bottle or two of dry gas.
Jokers69 is offline
Old August 28th, 2007, 12:28 PM
Past Administrator
Oldsguy's Avatar
Backfire is caused by incorrect timing. Could be that it just needs a tune-up, new rotor and distributor cap, could be the distributor hold-down clamp is loose, could be the timing belt slipped a link, or vacuum advance unit is bad. First thing to do is get a good tune up and verify timing. Also, make sure you have no vacuum leaks that would not allow full advance upon hard acceleration.
Oldsguy is offline
Old August 28th, 2007, 02:00 PM
Junior Member
88 coupe's Avatar
Originally Posted by Oldsguy
........ or vacuum advance unit is bad ........
Nothing to do with the problem.
It's primary purpose is to help increase fuel economy and it's secondary is to enhance "off idle" throttle response. At anything above idle, it only works under high vacuum (cruise) conditions.
A faulty diaphragm, could be the source of a vacuum leak, but it could not cause his symptoms.
........ make sure you have no vacuum leaks that would not allow full advance upon hard acceleration ........
When the engine is under load, there is not enough vacuum to move the diaphragm.
Other than that, you are dead on.
Norm
88 coupe is offline
Old August 28th, 2007, 03:49 PM
Redog's Avatar
Timing, or 2 wires are mixed up
Redog is offline
Old August 29th, 2007, 08:02 AM
millwrightrice
Guest
Posts: n/a
If its a old engine you could have a flat lobe on the cam.GM is famous for this.
Old August 29th, 2007, 08:23 AM
Past Administrator
Oldsguy's Avatar
Norm
Yeah, of course. The centrifugal advance would be kicking in at higher rpm where the engine would be under a load like that. I didn't think that one out first. Thanks for the correction.
Oldsguy is offline
Old August 29th, 2007, 11:34 AM
Junior Member
88 coupe's Avatar
Originally Posted by Redog
Originally Posted by shaks 442 clone
........ out of the blue my car started backfiring ........
........ 2 wires are mixed up
Not likely.
........ could have a flat lobe on the cam ........
Also, not likely.
Norm
88 coupe is offline
Old August 29th, 2007, 01:35 PM
Senior Moment
Jokers69's Avatar
Not likely.
Also, not likely.
Norm
so, instead of telling us whats not likely, how about what is likely
Jokers69 is offline
well i opened up the cap and found that the carbon button had melted
so im going to replace that either tonight or tomorrow and see what it does
also if you are not familiar with the name carbon button it is the brass piece that sits under the tiny spring of a gm hei cap
Old August 29th, 2007, 02:12 PM
Junior Member
88 coupe's Avatar
Originally Posted by Jokers69
so, instead of telling us whats not likely ........
Troubleshooting of this kind, is a process of elimination. Need I say more?
........ how about what is likely
When I have something better than I posted previously.
........ Other than that, you are dead on.
When/if I think of something else that actually fits his description, I will post it.
I am finished with your hijack.
Norm
88 coupe is offline
Old August 29th, 2007, 02:35 PM
Senior Moment
Jokers69's Avatar
cool. let us know how you make out..
Jokers69 is offline
Old August 29th, 2007, 02:38 PM
Senior Moment
Jokers69's Avatar
Norm
It's not a hijack, oh great one. It's a commentary on a very arrogant posting style. Where is the line to kiss your ring, I'll make sure I don't confuse that one with the beer line.
Jokers69 is offline
Old August 29th, 2007, 07:14 PM
Past Administrator
Oldsguy's Avatar
Good to hear it was the rotor. Always check the easiest and simplest first in these cases. A good tune-up goes a long way. Be sure to change the cap too, I bet the eight tower conductors are corroded and worn too.
Oldsguy is offline
Old August 30th, 2007, 07:18 AM
after replacing the cap and rotor (both msd parts) it is still backfiring
there has to be an underlying problem else where
i am going to try replacing bought collector and exhasut manifold gaskets next
by the way does anyone know a good way to get proper timing when you are running msd?
Old August 30th, 2007, 08:00 AM
Past Administrator
Oldsguy's Avatar
I think it would be the same way as with a stock distributor. disconnect vacuum advance and plug the source so there is no leak. Run car at idle and use a timing light to set the timing, adjust it by loosening the distributor clamp enough to rotate the distributor to get the desired setting. Are you using an MSD control box also? If so, I am not sure if there is anything to be done with it as I have no experience with that. I do know that the control box is supposed to change the advance curve for certain conditions. I also know there are different models, the MSD6 and the MSD7 but that is about as far as my knowledge of them goes. If you are using one it might be helpful to figure that out as well.
Oldsguy is offline
Old August 30th, 2007, 12:25 PM
Junior Member
88 coupe's Avatar
Oldsguy: He has a basic 6A box.
after replacing the cap and rotor ........
While you had the cap off, did you check the automatic advance for free movement?
........ (both msd parts) ........
All Delco ignition parts are up to the job. Any difference, in cost, was a waste of money.
........ going to try replacing bought collector and exhaust manifold gaskets next ........
If it leaks, it needs to be fixed.
Finish the tuneup (including a compression test) first.
........ good way to get proper timing when you are running msd?
MSD box is not a factor. Set it in the normal manner. 20° should work with your HEI, until your problem is solved.
The (unnecessary) extra impulses from the MSD, can cause erratic readings from some lights. If so, you can try a different light, or you can disconnect/remove the box.
Norm
88 coupe is offline
Old August 30th, 2007, 03:02 PM
Norm
what is the automatic advance? is it the thing that the cap screws down too?
Old August 30th, 2007, 06:14 PM
also all i have is a msd 6a box nothing fancy just the basic one with no rev limiter
Old August 31st, 2007, 01:48 PM
Junior Member
88 coupe's Avatar
........ is it the thing that the cap screws down too? ........
The spring/weight mechanism that is located under the rotor. It's also called mechanical or centrifugal, depending which manual you are reading.
Norm
88 coupe is offline
Old September 1st, 2007, 05:48 PM
oh well my motor blew up just yesterday
i was at my buddies shop and we found out what the backfiring problem was a broken vacuum cap on the carb fixed it re timed it and it ran like a top
on my way to work a few hours later i punched it on an open street then i heard clanking noises i threw it out of drive into neutral and turned it off till i rolled the the stop light
when the light went green i vranked it but it took nearly a minute to start i parked it on the side of the road next to the stoplight
after work my buddy came out turned it on and thought it was a broken flexplate we drove it about 5 miles then we noticed a lot of smoke coming out of the driver side exhaust pipe(the car has dual exhaust) from there we stopped it and towed it back to his shop
now im going to ride my bike to his shop and try and figure out what went wrong
just keeping you guys posted
if my car comes back with a 455 in it once again dont be surprised
Old September 1st, 2007, 08:53 PM
Tom Servo's Stunt Double
texasred's Avatar
Good luck! I've been following this thread but have had nothing to contribute beyond what others have said.
Hopefully you'll be lucky like me...had my car for 3 months and it suddenly sounded like a washing machine full of nuts and bolts. Poorly adjusted roller tip rockers and pushrods too long (via the previous owner) screwed up some valve tips, bent some pushrods and broke a guideplate!. Luckily it didn't wipe the cam and I got through the ordeal fairly quickly.
Unless, of course, you are looking for an excuse for a 455.....
C.J.
texasred is offline
Old September 2nd, 2007, 04:18 AM
Senior Moment
Jokers69's Avatar
aren't we all??..
Jokers69 is offline
Old September 2nd, 2007, 06:15 AM
Bummer that you had engine trouble. Since you were able to start it after hearing the noise hopefully it isn't anything too serious. If you threw a rod or had crank damage you would think that the car wouldn't even start. You might want to take the valve covers off and check the valve train. Maybe you dropped a valve or have a broken valve spring and had valve on piston contact.
Olds64 is offline
Old September 3rd, 2007, 04:09 PM
took the valve covers off and saw nothing out of the ordinary
took the number 6 spark plug out and the electrode was bent and a piece of the white stuff had fallen in the combustion chamber9
cranked the motor and the piston wasnt movin at all so maybe i have a broken connecting rod or broken piston
i wont be sure until the teardown starts
im going to stay away from the 455 swap just because the money i would spend on the engine i could put some nice forged parts in my 350
if my block is still okay i plan on going .30 over and havin a 355 displacement engine with forged pistons and crank a nice cam and valve train and an edelbrock 100 to 200 shot nitrious setup maybe heads im not sure right now because decent heads start at like a grand
i like the setup i spoke of because a buddy of mine knows a guy runnin the same setup in his 72 nova and he runs low 11s
Old September 3rd, 2007, 05:47 PM
Junior Member
88 coupe's Avatar
........ i plan on going .30 over ........
I'm guessing you meant .030". By going straight to thirty, you will probably be limiting your piston choices.
Find out what it will take to clean up the cylinders, then look at your options.
Norm
88 coupe is offline
Old September 3rd, 2007, 05:54 PM
  #31
$tryker's Avatar
Sad to hear Shaks442clone. Definitely use fordged with nitrous. Use Speed Pro pistons, that's the better choice. TRW will require additional clearance (.002). Good luck on the rebuild! Let us know the about the final product.
$tryker is offline
Old September 3rd, 2007, 06:09 PM
  #32
just call me shak lol
and definetly i will keep u guys posted
im always on here asking questions seeing as i dont know any people in my area who know a lot about cutlii
Old January 16th, 2014, 02:32 AM
  #33
carbyjack's Avatar
Had. Similar. Problems had the experts try ing to fix it. Ended fixing my self
Changed timing chain.
carbyjack is offline
Old January 16th, 2014, 06:40 PM
  #34
Today must be the day for dredging up ancient threads...
This one is from 2007. I think he got it fixed.
joe_padavano is offline
cutlassclay
January 16th, 2014 03:24 AM
76olds
November 26th, 2013 08:43 PM
84oldsDelta88
March 15th, 2012 09:29 AM
Wyze
April 3rd, 2010 06:29 AM
cts-v
June 18th, 2009 08:05 AM
Quick Reply: 1970 CUTLASS, BACKFIRING 350 ENGINE
