1966 Small Block heads with no number on them
Old Feb 25, 2020 | 03:30 PM
66SportCoupe's Avatar
Hey I have to ask has anyone else seen a set of 1966 330 small block heads without the #3 cast into them? I have a set off my 1966 F85 Deluxe. It's the original 310hp 4bbl engine.
This is off another 1966 310hp 330.
Old Feb 25, 2020 | 09:28 PM
edzolz's Avatar
Is there a number cast above the center exhaust ports. Should be three numbers on one side of the bolt hole and three on the other.
Old Feb 26, 2020 | 02:02 AM
Look at the pic you will notice those are not there either. They are under the valve cover between 2 valve springs.
Old Feb 27, 2020 | 08:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
A warranty replacement head? Any noticeable grind marks?
Old Feb 27, 2020 | 09:06 AM
No grind marks at all. Sequence number matches the POP card.
Old Feb 27, 2020 | 10:46 AM
It's not hard to grind off the raised number and then quickly hit the cast iron with a sand blaster to mask the grind marks. I have a set of J heads that someone did that to.
doc
Dec 15, 2014 01:00 PM
bw1339
May 12, 2014 07:16 PM
tds
Feb 11, 2014 01:05 PM
CutlassLegend
Aug 11, 2011 02:51 PM
