1966 Cutlass Manual transthrottle linkage
Old April 29th, 2018, 04:46 PM
35tac's Avatar
1966 Cutlass Manual trans throttle linkage. There is a (nylon ?) roller on the pedal end of the lever. Is the roller replaceable/repairable? See 1966 CSM page 6C-7, 6C-10 illustration. Roller has flattened and so is now not functioning as it is supposed to I am sure.
Wayne
35tac is offline
Old April 29th, 2018, 06:03 PM
Old School Olds
tru-blue 442's Avatar
Wayne, I don't think they are replaceable, but they can be lubed to roll.
I have this one if you need it, $20 + the ride.
tru-blue 442 is offline
Old April 29th, 2018, 06:28 PM
35tac's Avatar
Sending you a PM.
Wayne
35tac is offline
Old April 29th, 2018, 09:04 PM
RandyS's Avatar
I had one broken on my Red car. I drilled it out, then bolted on a replacement made from a screen door roller. Works perfect.
RandyS is offline
Old April 30th, 2018, 03:50 AM
35tac's Avatar
Randy, I had thought about rebuilding it that way. How much of a job is it to take the lever assembly out. The pedal is working by sliding which is not good long haul but it must have been working like this for a while. Did you have to readjust the throttle because of the change in the diameter of the wheel?
Wayne
35tac is offline
Old April 30th, 2018, 06:09 AM
RandyS's Avatar
Wayne
The wheel is fairly small, so I don't think it required any adjustment. It is possible to get the pedal linkage out of the firewall, but it takes a bit of twisting and turning. It was easy to drill out the old piece and bolt the new one in using a small bolt, lock washer and nut.
RandyS is offline
Old April 30th, 2018, 06:31 AM
Old School Olds
For those following this thread, there is one difference I have found.
There are 2 different lengths of throttle pedal rod. One is app. 6" and
the other is 7". I'm not sure why but it is worth mentioning for sure.
It may have to do with auto trans vs. manual. Anyone know?
Old April 30th, 2018, 07:20 AM
RandyS's Avatar
The one for a 4 speed is 6" long. (Must be to get those 3 deuces open all the way......)
RandyS is offline
Old April 30th, 2018, 09:17 AM
Kennybill's Avatar
This is a 1967 manual one. It also is 6 inches to open that big "Quadrajet."
Kennybill is offline
Old May 3rd, 2018, 01:26 PM
35tac's Avatar
Can you post the same picture without the tape measure?
Wayne
35tac is offline
Old May 3rd, 2018, 02:13 PM
The Rocket Astronomer
lunaboy's Avatar
Adam, it looks like yours has a weld to increase the length maybe I am wrong I have been known to see things.
lunaboy is offline
Old May 3rd, 2018, 03:17 PM
Old School Olds
Hey Luis, yeah. I'm not sure where it came from. Either from that 66 442 I parted or from a parts stash I got from Woody about 6 years ago. CRS, know what I mean?
Old May 4th, 2018, 09:48 AM
Kennybill's Avatar
I hope this is helpful.
Old May 4th, 2018, 10:14 AM
35tac's Avatar
Thanks, helped a lot. The one I got from Adam looks like it was extended for some reason. I am working with Joe to get some dimensional information to verify some information on the 66 assembly manual page. Your information is very useful. What I will really try to do is fashion a new spindle and roller assembly replacement for mine which has a good size flat on the roller. Great help thanks. Where in Ohio are you? I am in Medina south of Cleveland and west of Akron.
Thanks to everybody for the input.
Wayne
Medina, Ohio
35tac is offline
Old May 4th, 2018, 10:25 AM
35tac's Avatar
So this is the one Adam sent me. Totally different than yours. You can see the extension which looks like it was well done. I bought it from Adam for the roller parts so I could try to put a rooler assembly together. I will try to get a measurement of the arm off mine. I am not in a position to remove it now.
35tac is offline
Old May 4th, 2018, 03:26 PM
Kennybill's Avatar
Hello Wayne, I'm near Warren, OH. I was at the Carnation Mall Oldsmobile show and admired your car. You were busy directing traffic. Good luck.
Old May 4th, 2018, 03:40 PM
35tac's Avatar
Thanks for your help and hopefully see you at Alliance. I think I am going to pass on directing cars this year and enjoy the festivities.
Wayne
35tac is offline
Old July 25th, 2018, 01:31 PM
35tac's Avatar
Old subject but I just picked up a throttle assembly for my 66 for $30.00 plus some shipping. I would like to know if you remember how you cleaned this part up. That said it came out of a Jetaway Cutlass but it looks like bottom end is the same for either manual or Jetaway which veryfies that the page showing this in the assembly manual. So now I have a good replacement because the roller still rolls and has no flat spots.
Wayne
35tac is offline
Old July 26th, 2018, 06:25 PM
35tac's Avatar
Mission complete. I tore down the purchased unit and cleaned it up. The Jetaway part is scrap. Lower section with a very nice roller was fitted to the top end of the unit in my car. Wasn't to bad of a job but area is tight. It took about 4 hours total. Glad I have another job off my list. Lever is working fine. Your pictures helped a lot. See you at Alliance. I volunteered to park cars again.
Wayne
35tac is offline
goldie442
September 2nd, 2018 06:59 PM
android 211
March 7th, 2015 04:15 AM
L69
September 24th, 2014 03:33 AM
Larrys'66
April 23rd, 2014 04:23 AM
alexrains
January 3rd, 2010 04:39 AM
Quick Reply: 1966 Cutlass Manual transthrottle linkage
