1965 f85 st300 v6
Old Feb 8, 2025 | 10:49 AM
209bo19's Avatar
1965 f85 st300 v6
The F85 came with a Rochester BC single barrel and I would like to know if I can install a 2-barrel carb?
Thank you
Old Feb 8, 2025 | 11:42 AM
69CSHC's Avatar
Yes you should be able to.
The Dauntless V6 is your friend, you need the intake from a 1966 -1967 Jeep that came with this Buick engine 2bbl.
Old Feb 8, 2025 | 11:48 AM
69CSHC's Avatar
https://www.ebay.com/itm/33506725381...QAAOSwzMdlJuyU
Old Feb 8, 2025 | 11:58 AM
69CSHC's Avatar
This may assist you in deciding which way to go.
"1965 Dauntless used Rochester BC .
In my estimation it's one of the worst carburetors ever built.
1966 Dauntless used Rocchester 2G or 2GC.
In my estimation it's one of the best carburetors ever built.
Apparently the single barrel manifold tends to limit the volumetric flow on this particular engine."
oldtime,Nov 6, 2013
Post #7 of the following thread. http://www.earlycj5.com/xf_cj5/index...hreads/106263/
Old Feb 8, 2025 | 01:22 PM
Sugar Bear's Avatar
There is a good chance you could use 3.8L Buick V6 231 Odd Fire manifolds up through 1976. Downside is it would be an EGR manifold. The 225 and the Odd Fire 231 were the same except for a slightly larger bore on the 231. It was .010 larger bore IIRC.
Old Feb 8, 2025 | 01:23 PM
Why stop there?
Old Feb 9, 2025 | 08:10 AM
jmos4's Avatar
Hi,
Believe there were aftermarket 4bbl intakes made, seen a few posted on V8buick.com over the years.
Regards,
Jim
Old Feb 9, 2025 | 11:48 AM
Originally Posted by jmos4
Hi,
Regards,
Jim
Like the one I showed in the post right before yours.
Old Feb 9, 2025 | 01:57 PM
jmos4's Avatar
sorry vpn blocks pictures
Regards,
Jim
kburwell
Aug 8, 2014 06:03 AM
ccnclassicoldsmobile
May 7, 2014 08:05 AM
CalJim65
May 25, 2012 10:55 PM
GEORGE D
Aug 6, 2008 06:19 AM
