1964 Oldsmobile Cutlass 330
Old Apr 2, 2012 | 07:02 PM
Jonmueller1's Avatar
Question 1964 Oldsmobile Cutlass 330
My question is elementary, what is the tool to remove an original oil drain plug from the oil pan, a Torx T-70 or a hexagonal size say 5/8" alan wrench socket? I am having trouble getting the old one off so I can replace the plug with a new one...Thanks for your input JM
Old Apr 2, 2012 | 07:08 PM
rocketraider's Avatar
Oldsdruid
If you don't have the correct 8-point bit to remove it, use a 1/2" drive ratchet. Do not use an extension; all that will do is spin in the recess and round it out. Use the ratchet with no extension or socket.
Old Apr 3, 2012 | 05:17 AM
So that means just using the 1/2" wratchet head only. I will try that. I took it to a quick lube place and they thought that it was slightly rounded. If that is the case and the 1/2" wratchet spins then I will have to try a larger size. Otherwise can they drill a hole in it and back it out with a reverse thread tap? I also noticed that they tried sticking a thick rag with the torx bit they were using a T-70 and it didn't grab enough to break it loose. The special 8 point tool is probably hard to come by today. I appreciate your input.THX JM
Old Apr 3, 2012 | 06:55 PM
Smile 330 Oldsmobile drain plug
Thanks Rocketraider, put the 1/2" drive to the drain plug tonight after work and it broke loose, so took it up and had oil changed....appeciate your help! THX JM
Jonmueller1
Aug 8, 2015 07:55 AM
esteo
Oct 27, 2014 07:23 PM
dartphil
Jul 4, 2011 05:35 AM
pontiac1
Sep 14, 2010 07:06 AM
