1955 324 oiling diagram needed
The problem why you may not be getting oil to the rocker arms ( assuming you are priming the oil pump drive with a drill) is because the camshaft needs to be turning to force oil up the passages to the rockers. I learned this the hard way off a 394 and I am assuming the oil diagram is the same
