$1500 dollar budget to rebuild a olds 350
its a 70 block i want to at least do pistons, crank, connecting rods, cam, and new valve train
anyone have recommendations or am i out of my mind to do all that on a 1500dollar budjet?
the machine work shouldnt cost more then 200 or so dollars i believe also im going to install all the bearings and bolt on stuff my self with the help of the mechanic i apprentice for
just found out that my school might do the machine work on my block
i go to a community college and im in the automotive program, and i was talking to my teacher and his son was in the machine tool class and actually turned a 4.0 liter jeep engine into a 4.7 liter
so theres my question can an olds 350 be turned into a 383 with an olds 400 crank and from what year?
I don't think $1500 is enough to do an engine rebuild. When rebuilding your engine you should have EVERYTHING machined or you will regret it later. That includes punching out the cylinders, truing the deck, having the cam and main journals line bored, turning down the crank, having the connecting rods machined for oversized bearings, machining the valves and guides in the head, and having the heads trued. Does your school have all of the equipment to do that? When I went through school at CMSU they only had the machines to do the head and connecting rod machining. Then when I took it to the local machinist he could only punch out the cylinders and zero the deck and heads. He couldn't line bore the main or the cam journals. Not to mention turning down the crank. There is alot of machining that needs to be done on an engine when it is rebuilt. Of course, you don't HAVE to do all of this machining but I swore to myself that when I do another engine I would make sure I did it all.
I don't think that is enough. I am not trying to rain on your parade, just being reasonable. It cost me more than $200 for the machine work on the 455 I most recently rebuilt. Addressing the idea of having it done at the school; it might not be a good idea to do that, having the tools and equipment is one thing, having the skills to use them is also one thing, but having the experience to use them well is another. If you overestimate the amount of money you will need then you will have extra. If you underestimate the amount of money you need you will have a stalled project until you get more money to finish it. In my experience, momentum is very important ot keeping a project going and being stalled for money can really dampen the spirit and sometimes the project never gets finished.
I'll give you the vote of confidence Shak. When I was in Community College, I also did all the machine work that could be accomplished there. This included my own head (porting) work. Granted, your budget would only get you a standard bore bottom end. Most of my coin went into the cam and heads. I'm doing 11's in the quarter with no issues. Put the time in and you'll reap the benefits! Best of luck.
what year ? what type of car? what motor? tranny? gutted or full interior? and anything else important i may be missing
oh yeah nitrous?
also i wouldnt under estimate my school
they teach cnc machineing courses there and from what i have heard and read you cant get anything more perfect then on a cnc machine
Currently using a "68" 455 lower half with a Iskenderian cam, modified C heads, and a dual plane intake. Trans is a beefed th400, with 2800 stall, and 3:23 gears. Short 26 inch tires work great for this gear (not to mention highway driving). All in a 67 Cutlass Supreme with a full interior and no spray!
An early factory big block can achieve 13's in the quarter without much sweat. That's why I like the BBO. Do the machine yourself, I had a blast.
also are number 5 heads any better then number 6 heads and in what application?
btw my school can do everything but turn down the crank
and the teacher of the class has owned his own machine shop in oakland for 30 years now so he knows people who can do that
i was talking to him today and he was amazing he had all these bores and strokes and bearing sizes memorized in his head
i was like wow the whole time haha
GAOldsman
September 18th, 2012 08:07 AM
Napoleon Solo
July 13th, 2012 10:03 PM
