Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Water Pump Lengths
Old July 10th, 2012, 06:32 PM
Chesrown 67 OAI's Avatar
Bet yu find it to be alum. ive now bot 3 of em.
Chesrown 67 OAI is offline
Old July 11th, 2012, 08:50 AM
455man's Avatar
I was told the GMB 130-1260AL was the aluminum pump. The 1360 was for no A/C and 1260 was for A/C cars.
455man is offline
Old July 31st, 2012, 05:26 AM
HWYSTR455's Avatar
Man you guys got me all jacked up about the water pumps! I had to take mine apart because of the dreaded stripped timing cover bolt thing, and the pump topics have me losing sleep! But, from other 'brands', have a little experience, so figured I'd comment:
Blade design - You do want to choose a pump with the largest blades. Most list the A/C pump along with the 'towing' or HD pump, same one. And it seems as though those have the longer/larger blades.
Open/Closed design - Because Olds mounts against a flat surface (timing cover), it pretty much doesn't matter. What does matter is the distance of the pump impellers from the timing cover surface. Closer = better. That would be controlled by the gasket. You could use some dumb-dumb and figure out what the distance is, but getting it closer than the thinnest gasket available may be a tough feat. As previously mentioned, the closed design probably requires the thicker gasket.
Blade clearance - Another area that would impact flow is the distance of the blade from the body of the pump. If the blades are bent, obviously you don't want to use the pump, but if you are able to compare some next to each other before buying, get one where the blades are as close to the body as you can find. You could probably close that gap up too, like by gentley tapping the blades, but you would have to be careful, and support the snout of the pump to not stress the seal or bearing.
Aluminum vs Cast Body - Personally, I would think the cast ones are better, since it's going to be more stable around the bearing & seal area. Cast will also expand & contract at the same rate as the rest of the engine. For a minor weight savings, don't think it's worth it.
HWYSTR455 is offline
Old June 7th, 2013, 09:01 AM
young olds's Avatar
Does anyone know if the short 5" pump is available in aluminum? if so whats the part number, I wanna go aluminum just for the looks but want the short pump either way.
young olds is offline
Old February 3rd, 2014, 10:00 AM
Octania's Avatar
Originally Posted by OLDSmobility
Here's a breakdown of Oldsmobile water pumps, showing year and application and height, as well as part numbers and casting numbers.
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
That chart needs
1) color coding for the three different lengths
2) MAIN CASTING ID INFO, the huge mark you can read from 20 ft away
3) Inlet nipple info.
Otherwise, exceedingly nice compilation.
Octania is offline
Old February 3rd, 2014, 10:19 AM
Originally Posted by Octania
That chart needs...
...a little cleanup also. For example, I'm not sure why the 54-56 entry needs "exc F-85". While that ISN'T incorrect, it's a little misleading. Also, the conflicting data in the tables below the main one on the 68-69 W-car and H/O pumps taken from the Mondello tech manual needs to be verified and cleaned up.
joe_padavano is online now
Old February 16th, 2014, 05:02 AM
75 W-30 H/O's Avatar
So my non-A/C 75 455 uses a 5.5" pump (I'm so confused)?
75 W-30 H/O is offline
Old February 16th, 2014, 07:32 AM
W30Olds's Avatar
I'm perhaps in a dilemma myself with these pumps. Went through every major parts store/supplier in the area with no avail. Either they're too long or a tad bit too short. I have to continue my search for a 5.072 short housing pump.
I think it would help if all the parts stores websites actually listed what the lengths of all the water pumps listed were.
W30Olds is offline
Old February 16th, 2014, 08:26 AM
Hookers under Hood
76olds's Avatar
I have been trying to get an aluminum water pump for my 350 76 cutlass supreme w/ac single pipe up here in Toronto, been to performance improvements and they say there are none available, does anyone know if they make one for this car?
76olds is offline
Old February 16th, 2014, 09:21 AM
Octania's Avatar
Anything this side of 1973 or so with or w/o AC should use the uber-common 6.1" pump. POSSIBLY no-AC cars used the 5.6" pump, but by then almost all cars came with AC so otherwise is pretty rare. E.g.,
22526206 factory unit
1260 or 1360, whichever is the correct length
Octania is offline
Old February 16th, 2014, 12:08 PM
Hookers under Hood
76olds's Avatar
I seen them on summits site however they have 2 heater hose pipes, My pump has only one pipe the other heater hose runs to my radiator, I guess I would just plug one .
76olds is offline
Old February 19th, 2017, 08:04 PM
swampmobile's Avatar
Waterpumps -
Originally Posted by Chesrown 67 OAI
Do you have the information as to the outlet size on these different pumps? I have fould parts suppliers that list a pump with 1-3/4" outlet and others with 2" outlet? Would it be safe to assume that the short shaft non/ac pump would be the one with the 1-3/4" outlet?
Thanks for info!
Very helpful - thanks!
swampmobile is offline
Old March 14th, 2017, 10:55 AM
sep455's Avatar
The Advance water pumps, now in a CARQUEST box, T-3085 & T-3086 both listed for a/c are 5.95" long. The T-3072 pump is 5.57 long and is listed for non a/c or OAI hood? I had to use the shorter pump T-3072 for my original '72 H/O 455 that had a/c, go figure?
sep455 is offline
Old March 14th, 2017, 11:02 AM
Well, rather than relying on Advance (or any other aftermarket parts source) for reliable Oldsmobile information, you should crack open your Chassis Service Manual, which has this diagram showing 5.57" as the correct pump for your application.
Old March 14th, 2017, 12:16 PM
sep455's Avatar
Your right Joe, great pic, i just wanted others to know about my experience so they wont make the same mistake, thanks, Steve.
sep455 is offline
Old March 14th, 2017, 01:13 PM
One thing you can almost always be sure of is that an aftermarket application listing for Oldsmobiles will likely be wrong. Whether it's water pumps, motor mounts, headers, or whatever, these application guides have serious errors.
Old March 14th, 2017, 08:46 PM
Mr Shifty Sidney's Avatar
Unfortunately factory books are not always correct either. Cutlass/442s in 71/72 used 3 different water pumps.
5.0" no a/c, no h.d. cooling, no W-30
5.5" W-30 no a/c
6.0" A/C or H.D. cooling
​​​​​​​Don W
Mr Shifty Sidney is offline
Old September 25th, 2017, 05:17 PM
  #58
derone's Avatar
I'm in the 11th hour of building the drive train on my 72 cutlass 'vert. It originally came w/350 2bbl, no air, and now it's a 4bbl, still w/o air(so far).
Anyway, the water pump ordeal has become quite a learning experience. 3rd party parts books didn't add up. I did find a stout 5" pump and the model is a Airtex AW773. Then, the 2nd problem was that it has a 2" inlet and the lower radiator nipple was 1.5". Again 3rd party parts books didn't add up. Ended up downloading the Gates molded hose catalog to find the closest hose, I could find myself. Nice catalog, sorted by part number or size w/pics. I ordered the 23095, which I think is a bit longer than needed, but still closer than any of the other options in there. I'll know more after it arrives this week.
derone is offline
Old September 25th, 2017, 05:30 PM
  #59
All you need for lower hose is the rubber sleeve Olds used on the lower radiator outlet that bushes it up to your standard 2" lower hose. Ive had several of tgem over the years.
Old September 25th, 2017, 07:34 PM
  #60
derone's Avatar
Wasn't aware they made those hose adaptors, but did find them at Summit.
Most of the Cutlass replacement lower hoses I've seen are either 2"WPx1.75"RAD or 1.75"WPx1.75"RAD or 1.75"WPx1.5"RAD. I could use the 1.75 to 1.5 adaptor and the 2x1.75 hose(20595) if my plan doesn't work out. It has to be a molded hose, no flex. Thanks for the option.
derone is offline
Old September 25th, 2017, 09:44 PM
  #61
70 and earlier water pumps have a 2" hose nipple and 71 and newer have a 1.75" hose nipple. Sounds like you got a 68-70 water pump.
Fun71 is offline
Old September 26th, 2017, 05:48 PM
derone's Avatar
Yep, probably a 68-70 5" water pump. So, today I take back the pencil branded Dayco D70650 lower hose and the parts store had a real D70650 hose waiting....low and behold this was fix. A true 2"x1.5" perfectly molded hose for the cutlass. I'll send the Gates 23095 back as soon as it arrives. Hope this helps someone else down the road, as I've learned quite a bit just browsing around this forum. Life is good again. Doug
derone is offline
Old February 16th, 2018, 01:51 PM
  #63
gtuturbo's Avatar
So, looking at replacement water pumps for my 66 330ci with no AC, I have acquired the following data:
This pic from my service manual...
....and this casting info from Oldsmobility
makes it appear I need to buy this water pump---
Looking for confirmation that I am most likely correct?
gtuturbo is offline
Old February 16th, 2018, 02:17 PM
  #64
The casting number on that new pump is correct.
Old February 16th, 2018, 04:06 PM
  #65
gtuturbo's Avatar
Thank You.
gtuturbo is offline
Old March 26th, 2018, 05:08 PM
  #66
72sup350m20's Avatar
My 72 Supreme 350/m20, no ac had the shortest, 5.1 with a 2" inlet (384783 casting). This thread saved me a lot of trouble! Thanks to everyone! All the parts stores list the middle length for my car which is wrong. I have a spare 72 350 4barrel engine from an ac car and it has the longest pump (6").
I just visited our local NAPA which still has the old books behind the counter with hub heights and inlet dimensions for pumps. Unfortunately their new 5.1/2" pump is discontinued (43120). They only offer a reman (58-293). Keep those old ones if you have them. I'm hanging onto my original for a rebuild some time in the future.
72sup350m20 is offline
Old March 26th, 2018, 07:10 PM
  #67
Rock auto still has all 3 lengths, iron and at least two of the 3 in aluminum
Old March 28th, 2018, 05:38 AM
  #68
For rad hoses, I assume the top hose never changed between 1970 and 1971. For the lower, I assume the lower rad hose was for a 71 model as there was an Olds 260 in it when I bought the car. The hose fit my 6" Flowkooler aluminum pump that is on my 350. So I assume, hoses for a 1971 Cutlass should be ordered for my 70S due to the later water pump? I plan on ordering spare Gates hoses, I like to carry any easy replaceable parts for these old cars in the trunk.
Old March 28th, 2018, 06:48 AM
  #69
The 1971-later engines got the larger water pump inlet and the larger NPT thread at the back of the intake for the nipple or heater control valve.
Old March 29th, 2018, 07:40 AM
  #70
I assumed so. I will order hoses for a 71 Cutlass.
Old April 3rd, 2018, 03:31 PM
  #71
NAPA reman water pump I picked up is casting number 398681.
Old August 9th, 2018, 09:37 PM
  #72
shatrab's Avatar
So I was at Olds Nationals in Gettysburg last Friday and was walking through parts areas with a friend, Eric who recently bought a 68 442 (I have had one also since 2011). My friend was stoked about the KA water pump pulley since I told him my car’s story as having it on the car and not knowing the significance on top of all the other W30 indicators. He had me help look through a few crates of pulleys looking for the “elusive” (in Chris Witt’s words, RIP Chris) KA pulley. I repeatedly told him we would never in a million years come to an Olds event (let alone Olds Nationals) and find that pulley unless it was for unbelievable money. We went to a table and found one (which shut me up for a little), that was so pitted and sand blasted (but had a barely discernible “KA” on it)... Tag said $500.00 and person selling wasn’t there as one of the people behind table said it had to be $5.00, not $500... I told him it is rare and marked correct and woman who got into discussion confirmed it was $500. So we walk about 10 more minutes and come up to a spot where a very nice older fellow from Oklahoma had a wire tied set of crank and water pump pulleys that had yellow paint pen marks that it was for 68-69 W30 442. I picked up the set that was in a 100% better shape then one I mentioned above that was $500.00 (that must have been in the bottom of a water barrel for 40 years). The large pulley (waterpump) was in fact marked KA and the set was in great shape. The tag said $200.00 and when we asked the seller about it (I was excited it said $200.00), he looked at the tag and said he didn’t know who wrote that on it ($200.00 price). Both Eric and I first felt guilty that he might have thought that we wrote that on it (neither of us would do that), and he said $50.00 for the set! Eric bought the set (obviously) and for the next hour he was scratching his head that it had to be a repop but I explained to him it is exactly like mine and is a set for $50.00... Even a repop that could possibly look that original could not be sold for that cheap. We returned a little later because I told Eric the waterpump may be a special height meant for that set of pulleys (I wasn’t sure at the time, just knew I never had to worry about that myself as my car came with the KA waterpump pulley and everything lines up ok. So now I am scratching my head as to how something that I knew never could happen to me or Eric at any parts swap (finding a KA waterpump pulley for such a reasonable price), and was thankful to find out that this seller jur set up Friday as Thursday was a complete rain-out (and we were only there Friday)... Meant to be for a good friend!
Here’s the interesting part that I hope someone can explain... The fellow from Oklahoma had other parts he said all were extra parts he was cleaning out as he had W30’s in the past. He had one waterpump that had 398681 on it, and Eric bought it for $40.00... It would be somewhat reasonable to deduct that the waterpump might have been on the same car as the pulley set, but the listing under the Mondello chart shows this as 69-69 400 and 455 W-30, W-32 or Hurst/Olds without AC or HD Cooling. What W-30 didn’t have HD cooling? Every thread I see says 400269 (with A/C or HD Cooling)... Is the 398681 correct for a W-30 in 68-69? Just curious as Eric feels he got the wrong water pump (and that the 400269 is correct). Any thoughts on what W-30 in 68-69 did not have HD Cooling?
Thanks!
shatrab is offline
Old August 10th, 2018, 06:44 AM
  #73
Well, I don't know what "Mondello chart" you have, but any document that doesn't come directly from the factory is suspect. Even factory documents contain typos and errors, though these are usually corrected in either subsequent printings or dealer bulletins. Here are the factory pulley sheets and listings for 1968-69. P/N 401462 is the pulley used on W-30 and HD cooling.
Old August 11th, 2018, 02:18 PM
  #74
therobski's Avatar
I'm going to replace the water pump on the 400E, in the 64 F-85. Read everything above and checked out a few other sites about the pros and cons of rebuilt aftermarket water pumps and I'm going with a new FlowKooler Hi-volume 1775 . Yes more expensive, plus replacing a water pump is a little more involved on this build. I'm getting a bit older and going to be taking the Old's on some cruises soon, I want to minimizes chances of failure. As you can see in the pictures, there's not much wiggle room That's a 6 inch water pump with later Old's pulleys and accessories. Others have said for the extra $$$ for a FlowKooler is $$$ well spent-very pleased. My 2cents...
therobski is offline
Old August 11th, 2018, 06:50 PM
  #75
Pump
You're wasting your money buying that expensive pump. It will do no brtter then the GMB pump.especially with a good alum radiator and good electric fan like you show in your pix
Old August 12th, 2018, 10:09 AM
  #76
I live in Phoenix and drive around in 110+ degree summer temperatures and I don't have any cooling issues using an auto parts store reman water pump with the crappy stamped steel impeller. I had considered getting a pump with a better impeller design but ended up trying the parts store pump and since it worked I never changed it out.
Fun71 is offline
Old August 12th, 2018, 06:29 PM
  #77
shatrab's Avatar
Thank you for all that information Joe. I may have confused you and others to my question (my last paragraph of my last post). My comments about finding a KA waterpump pulley was just a side story. What I was asking was about the waterpump my friend Eric and I found that had 39861 on it. The Mondello info I referenced was from posting #26 in this thread in the hyperlink to area of “Special notes on waterpump casting numbers.” Maybe I incorrectly referenced it as being Mondello, my apologies. It shows the 398681 for 68 and 69 W-30, W-32 and Hurst Olds w/o AC or HD cooling... My question was basically what W-30 did not have HD cooling (I am rusty, but the V01 cooling is HD?)... Most will say the 400269 is correct, I get that (notice and it was discussed above in earlier postings that the 400269 is incorrectly listed as 400289, but that is besides the point...[). Just wondering about the 39861 waterpump application...
Thank you.
shatrab is offline
Old February 19th, 2020, 01:16 PM
  #78
dduvall's Avatar
Many thanks to the experts the contribute to this site. Ordered a water pump for a 71 350, non air and they sent the air cond. pump.. in a few minutes I was able to fine a link to a page with casting numbers and lenghts ect and was able to give my parts guy a valid number. Thanks again
dduvall is offline
cjsdad
June 27th, 2015 02:03 AM
SkylinesSuck
August 4th, 2014 05:59 PM
Nasty455
March 11th, 2012 09:42 PM
ROCKET VAPOR
February 10th, 2011 06:36 PM
442garage
August 9th, 2010 07:50 AM
Quick Reply: Water Pump Lengths
