Olds 442 hood
If you want to run the fiberglass hood then I'd encourage you to stash the original 442 hood in the back of your garage. Your other post said its all original so I'd not do anything that couldn't easily be undone. My 2 cents worth!
John
John
This is a matter of personal taste, but the W-25 hood was designed to fit with the body lines and grille design of the 1970-72 cars. The scoops are designed to align with the grilles, and the leading edges of the scoops parallels the leading edge of the hood. The ones on the market for other years retain the scoop size and shape from the original and don't match the later cars' lines at all. Your call, but I prefer the original hood.
Yes, I realize these aren't 1974 model year, but they were the photos I could find quickly. Note that the outside edge of the scoop is outboard of the feature line on the hood instead of lining up with the grille and the leading edges of the scoops don't parallel the hood or header. Looks like a force fit instead of an integrated design.
At least on the 73-75 hoods, the scoops parallel the leading edge, but the openings are not even close to aligning with the grilles.
I know Joe, took his vision and made it work. He said the same thing as many have said that the VFN based on 70-2 W-25 aren't quite there with alignment etc.
I should get a pic of bottom to see how they dealt with that.
Brett
Brett
The irony is that the skills used to fit those OAI hoods onto later cars are the same skills which could've been used to fix the aesthetic problems you note.
Hurst/Olds 73/74
September 24th, 2016 09:31 PM
Ctls442
July 26th, 2015 11:15 AM
theoldsrocket
March 24th, 2011 01:03 PM
guy.graziano
December 5th, 2010 12:10 PM
georgiaboy697
July 2nd, 2010 09:23 PM
