69 442 Options
69 442 Options
I have recently purchased a Beautiful 69 442. I have spent a good deal of this morning reading posts of Vin # decoding, but did not find any answers to my question. My question to the many Olds experts here is: Is there any way to find what Options my car was originally produced with.Body by Fisher reads as follows.
ST 69-34487 BF 03231 BDY
TR 933 B80 69 69 PNT
04B 142597 660709
No other tags or build sheets have been found yet.
Car has 400 BB, 4 speed (Close Ratio), AM/FM stero, Rally Pac gauges with Tic Toc Tach, AC, Power Steering, Power Brakes, SSII wheels(14 in) Bucket seats w/ console. Can't thing of any other present options at this time.
Any help will be greatly appreciated.
Jerry
04B 142597 660709
Jerry
04B 142597 660709
Jerry
04B 142597 660709
Jerry
Thanks Joe for the fast response. You have told me what I was afraid of. I do intend on removing the tank in the near future so maybe I'll get lucky. Not betting on it but stranger things have happened.
Jerry
Jerry
Here's what your trim tag does say.
ST 69 = style/model year = 1969
34487: 3 = GM division = Oldsmobile, 44 = model series = 442, 87 = body type = holiday coupe
BF = assembly plant = Fremont, CA
03231 BDY = Fisher Body number assigned by Fisher Body; has no relation to your VIN
TR 933 = interior color and front seat type = blue interior with bucket seats
B80 = option code for exterior drip scalp mouldings
69 69 PNT = lower and upper body colors = platinum for both
04B = time build code = April (04), second week of that month (B), 1969
Your VIN should look like 344879Znnnnnn where n = a six-digit sequence number assigned at the assembly plant
There are ways of telling if certain items are original to your car. The VIN derivative (39Znnnnnn) will be found on your engine block on a raised pad on the driver side of the block below and slightly forward of #1 cylinder. The same VIN derivative will be stamped vertically on the driver side of your transmission housing.
There is a pamphlet published by SuperCarsUnlimited in Beaverton, OR, titled "4-4-2 By The Numbers" that will tell you a lot about your car. You can order it from their web site (www.supercarsunlimited.com) if you like. Their motto: "4-4-2 is all we do"!
I also highly recommend purchasing a hardcopy version of the "1969 Oldsmobile Chassis Service Manual", a hardcopy "Body By Fisher 1969 Service Manual", and a 1969 4-4-2/Cutlass Assembly Manual. All are invaluable in learning about, and conducting maintenance and repairs on, your 4-4-2.
Randy C.
Randy C.
Thanks Joe
I think this car is sharp. It's almost exactly like the one I owned in 1969 except that one also had a blue vinal top. I have a couple pics in another post here. I'm not very computer literate or I would attempt to post additional pics.
I believe that it is a close ratio M 21. The #'s on the gear set are 3A72 GM ZG 337. If anyone can de code these #'s, then I can know for sure.
I may attempt to convert to a M 20 later on. I like the wide ratio much better.
Jerry
Jerry
Thanks for the print out. I was scheduled to receive my manuals today but the good ole post office sent them to a complete different city so who knows when I may get the manuals now.
Received my Chassis Service Manuals today so maybe I won't be asking you guys to do research for me that I can now do myself.
Thanks for the info you guys gave me Now I just need to learn how to use this site much better.
Jerry
Jerry
I now must agree with the experts. I must have a M 20 diff. I thought with the way it winds thru the gears that it had to be close ratio, but I stand corrected. I guess that my memory is failing me in regards to how my original 442 drove in the 60's and early 70's.
Sure sucks getting old
Jerry
Jerry
there are numbers on the side of the trans, start with a P and usually end with a letter (A M20, B M21, C M22), that will help decode what it is. That doesn't guarantee what is still inside however, but we would know what it was originally.
RAMBOW
March 23rd, 2009 02:05 PM
