Wall of shame
#367
honestly I don’t know, there is no sign of impact on suspension or wheel, I was talking to customer and she said brake were just completed a few weeks prior, pads were wore out 2/32 parts did look new, I am thinking cheap china parts, customer declined work and is bringing a replacement rotor from the shop that preformed brake job
#368
Oh no, not again...
Location: Sherwood Park, Alberta, in the Great White North
Interesting thread, I haven't laughed this hard in a while.
The scary thing is when cars with major structural issues like some of those depicted here are sold as solid transportation to people who can least afford to fix them.
#371
A friend of mine once had his car at the tire shop, and the tech told him he had a "Maypop". My friend gave him a confused look, asked what the hell a "Maypop" is, and the tech grinned and showed him. It was a bubble on the sidewall of the tire. The tire "may pop."
#373
Spent a good half hour going through these. Good fun though I'm not sure what I'm looking at in a few of the pictures.
The funniest story I heard was told to me by a coworker when I first started working 30 years ago. Another coworker was doing something where he needed the accelerator pressed down a bit so he wedged a block of wood between the brake pedal and the accelerator. He left the wood there and his wife got in the car, started it and shifted into reverse. Pushing down the brake just resulted in going faster in reverse. She went down their driveway, and then up the neighbor's drive across the street, into their garage and busted through the back wall into the neighbor's back yard. There, she proceeded to do donuts in reverse. She continued doing donuts in their backyard. When asked why she didn't just turn off the ignition, she said the only thing she could think at the time was 'I just filled up yesterday!'
#374
#378
This guy comes into my shop with a 2015 F-250 and says "I was getting off the freeway and when I hit the brakes the pedal just went to the floor".
He pulled in using his trailer brakes. He was towing a 9000lb trailer.
#379
And, yes, both pistons of the master cylinder, which are different sizes, are feeding the same single brake line.
As for the copper, there is copper brake line that is legal. It comes in bulk rolls and is not cheap, but if you are redoing a number of cars, it is much easier to work with than steel, and it is immune to salt.
There is no "copper" brake tubing. There's Copper-Nickel alloy that's used for brake and fuel tubing. I've never worked with it.
I've got a Pinto rotor where the fins are showing, and the braking surface broke away from the hub...but there's been plenty of others just like it posted here. As usual, the car drove into the shop. "The brakes have been grinding for awhile..."
My own story: Driving a 1980 Honda Civic 1300. The 1500cc version has iron block and a catalytic converter. The 1300 (mine) has all-aluminum engine, and no need for a catalyst.
58,xxx miles, driving in fifth gear at ~70 mph down the interstate at midnight in February. Engine stalls, oil light comes on, I instantly kick the clutch and coast to the side of the road.
Discover upon teardown that four main bearings look like new. Three rod bearings look like new. One rod bearing is burnt black, worn so sharp you could shave with it, and the connecting rod is in four main pieces, BUT NEITHER ROD BOLT BROKE. (If you could undo the rod bolts, it'd be six pieces plus the bolts and nuts) It's the only broken connecting rod I've ever seen that DIDN'T fail the bolts. (I've seen photos of others, but never saw 'em in real life.) At the time--1985--I took Polaroid photos of the rod, and the original photo got singed. All I have now is the damaged photo, which I then took a digital photo of. So here's a picture-of-a-picture complete with singe-marks.
Naturally, the rod pieces blew a hole in the block directly in-line with the edge of the oil filter. I kept the piece of block, plus the rod fragments for years. Lost them some time ago.
#383
#388
#394
I don't know if this is more of an advisement or a wall of shame item.
Kept smelling fuel on the Cutlass and couldn't figure it out. All the lines were new so after a long trip I popped the hood and saw the intake nipple on the fuel pump was wet. I'm guessing in the past it evaporated before I could find it. Anyway thought the rubber fuel line was loose because I was able to roll it back clock wise and counter clock wise. wouldn't tighten anymore. When I tried to pull it off the nipple came out of the fuel pump. Luckily the car didn't go on fire. No Idea what make as it was on the Frankin Cutlass when I bought it.
One
Two
Holy S!@#
One
Two
Holy S!@#
#395
One
Two
Holy S!@#
One
Two
Holy S!@#
