#4 (67 330) SBO Olds heads $300
Old September 5th, 2018, 07:13 AM
GEARMAN69's Avatar
I have a running pull off pair of #4 Olds small block heads off a 67 330 4 barrel also the 67 4 barrel intake to match. these have the smallest chamber giving the best compression upgrade on your 350 or 403 Olds that has dished pistons. The heads were previously rebuilt and had hardened seats installed and also have screw in studs and guide plates included. Stock valve springs will need upgrade to match your camshaft. $300 Ennis Texas area zipcode 75119 along I-45 / US 287 just S of Dallas local delivery gearman69@netzero.com
GEARMAN69 is offline
Old September 20th, 2018, 10:22 PM
72 Cutlass Ponca City OK
bigrbandit's Avatar
What size are the valves? Do you have any pictures? Retainers or rotators? All the same pocket height? I'm in Ponca City, OK. I'm guessing shipping on heads would be like $80? 5/16 or 3/8 studs?
bigrbandit is offline
Old September 25th, 2018, 10:20 AM
GEARMAN69's Avatar
I need to pull them off and get the pics, meant to a while back The valves are stock small valves but will measure. The studs are the 3/8 ones up top and 5/16 thread underneath Being a 67 it has no rotators and stock springs and retainers as far as I know that would install I think at 1.67" for intake and exhaust. I saw the hardened seats when I put new seals before installing them on the fresh rebuilt low compression stock 350 I had acquired. These heads hadf a stock rebuild prior to me owning them but were very clean. We have a wedding to go to in Oklahoma in October 19-20th and will be in Catoosa on the E side of Tulsa if you want me to bring them ?
Old October 15th, 2018, 11:56 AM
GEARMAN69's Avatar
bump
Old October 20th, 2018, 01:30 PM
bmanrrt's Avatar
Hi, I am brand new to this forum. I was refered here by a guy from a trans am forum. I have a 68-70 olds 350 probably with dished pistons, so I might be interested in these heads. I am waiting to hear back from a guy here locally but I wanted to reach out and see if these are still available?
bmanrrt is offline
Old October 22nd, 2018, 06:49 AM
GEARMAN69's Avatar
Still available but not really wanting to ship , where are you at ?
Old October 25th, 2018, 08:35 AM
bmanrrt's Avatar
Sorry for the delay, I read your post a few days ago, but I forgot to come back to respond. I am in Phoenix, AZ. Shipping would be the only way. I am still waiting to see if I can find some locally too, for the same reasons.
bmanrrt is offline
Old November 20th, 2018, 08:50 AM
GEARMAN69's Avatar
BUMP , 67 4v 330 intake goes with it for $300 , a friend has the matching short block he would probably sell cheap too
Old February 21st, 2019, 11:53 AM
GEARMAN69's Avatar
$200 w/o the 3/8 screw in studs/guide plates/ 1.7 roller tip rockers or $300 for all
Old June 11th, 2019, 02:11 PM
all olds...all the time
iam2fast4u86's Avatar
Still have these?
iam2fast4u86 is offline
Old September 16th, 2019, 02:24 PM
GEARMAN69's Avatar
Originally Posted by iam2fast4u86
Still have these?
Sorry for late response . I usually just look for messages here. Not available at the moment. I sold the 1.7 rockers, scrapped the studs I had on it and re set them up with new HP springs , better hex head Comp screw studs and poly locks on 1.6 roller tip rockers along with new cam and roller chain in that (mule) 87 octane 350 I was using them on About to reinstall that engine again for cruise duty.
Old September 16th, 2019, 07:33 PM
65B01Delta's Avatar
PM Sent
65B01Delta is offline
Old September 17th, 2019, 02:30 PM
GEARMAN69's Avatar
Originally Posted by 65B01Delta
PM Sent
didnt get one
Old April 23rd, 2020, 11:58 AM
GEARMAN69's Avatar
Sold locally
MudEye
September 21st, 2017 09:47 PM
67442nut
November 22nd, 2015 07:16 PM
1978 Oldsmobile Omega
August 12th, 2014 06:00 AM
acre03
March 29th, 2009 03:11 PM
67htc
July 22nd, 2007 07:41 AM
Quick Reply: #4 (67 330) SBO Olds heads $300
