Need speedo right angle adapter for 4 speed
Old September 5th, 2018, 10:15 AM
Tjohn8573's Avatar
Hello Everyone, I am llooking for the right angle speedometer adapter that is at the Muncie M20 side of the speedometer cable. I’m not having luck locating this part or a replacement. Anyone have one, know where to get one, or suggested alternate part?
Tjohn8573 is offline
Old September 5th, 2018, 10:25 AM
72455442RA's Avatar
I have those ...
but...
they are also used as a speedometer corrector .... when doing a rear gear or tire diameter change ..
like .982 .878 ratios ....just examples ... not actual numbers
I dont think any are 1-1 tho ...
I can took tonite
Scott T
from py
72455442RA is offline
Old September 5th, 2018, 10:35 AM
ROCKETMAN269V's Avatar
It would help to know what year your car is, what gear you have in the rear end and if you have changed from the factory tire size. I have a few of these adapters. Thanks, Bob.
ROCKETMAN269V is offline
Old September 5th, 2018, 11:47 AM
Kennybill's Avatar
Just curious. I've seen a right angle adapter when using a passenger side speedometer Muncie in a BOP A-body drivers sided speedometer cabled car. I always thought the right angled one was only so one could use the existing cable. I had a 1965 Malibu SS (first year of passenger side Muncie speedometer) and it was passenger side speedometer Muncie. I believe BOP were drivers side to 1970 then all Muncies went passenger side. Do you need the "correcter" or the cable "enabler".
Kennybill is offline
Old September 5th, 2018, 01:37 PM
Tjohn8573's Avatar
Thanks for the replys. What an awesome group! I guess I would be looking for something would come stock with the M20 1968 442 Muncie with 3.42 gears. I’m not sure what size tires that I am going to end up with. I thought that you could put in the different speedo gears for what setup you have. I’m clueless I guess I just thought there would be one kind of adapter to make it 90 degree angle.
thanks let me know what you think.
thanks
Old September 5th, 2018, 01:48 PM
Tjohn8573's Avatar
Ok I’m learning maybe it is 1.1320?
Attached is a pic of what I am looking for.
Old September 5th, 2018, 03:03 PM
Ancient Iron's Avatar
If your car came with a 3.42 rear and still has the wide ratio M-20 than the correct ratio adaptor is 1.1320.
They were made by Stewart -Warner.
Mine was broken when I got my '69 and I needed the same one. I hate to tell you It took me 20 years to find one.
Ancient Iron is offline
Old September 5th, 2018, 03:58 PM
35tac's Avatar
Have you seen this item on E-Bay 372349806075. Is this what you are looking for?
Wayne
35tac is offline
Old September 5th, 2018, 07:03 PM
steverw's Avatar
I was using a right angle adaptor that i bought years ago for the tach on my Corvette. The tachs are gear driven off the distributor, as it turned out i was better of without it on the Vette. So adding a Gear Vendors OD to my car seemed to put the speedo cable in a bit of a bind and i used the tach drive adaptor. It worked great until it came apart. Any Corvette vendor would have it, Ecklers, Mid America, Zip. I ended up pulling my cable up some and it fit after all on the OD, so i never bought another adapter. Not sure why it came apart, it looked pretty stout, but it did. They do not change the ratio its just one to one.
Hope this helps
So the adapter 35tac is talking about on EBAY in the post prior to mine, is the same as i used, If you get one perhaps you should lock tite the threaded parts so it dosent come apart.
Steve
steverw is offline
Old September 6th, 2018, 01:15 PM
Kennybill's Avatar
This is what I was talking about so a driver's side cable would reach a "passenger" sided transmission. I believe BOP had driver's side Muncie transmissions till 1970 then they went to the Chevrolet styled passenger side which Chevrolet started in 1965, jmo.
https://rover.ebay.com/rover/0/0/0?m...2F372349806075
Old September 6th, 2018, 08:20 PM
Gerald Nickels's Avatar
The one I have is like a half German swastika.
Gerald Nickels is offline
onofre442
August 30th, 2017 08:56 AM
Jim Kniola
November 14th, 2016 04:30 AM
jerseymike
May 7th, 2013 12:13 PM
CaptOharry
November 11th, 2012 12:41 PM
69oldsguy
March 3rd, 2010 07:55 AM
Quick Reply: Need speedo right angle adapter for 4 speed
