spark plub wiring for HEI on a 65 330
Old September 1st, 2018, 11:47 AM
ankerclanker's Avatar
Okay, maybe a dumb question, but what is the correct wiring for an HEI ignition, from dist to plugs. where can I find a diagram of the wiring order. changed plub wires(car was running okay, wires were kinda short), screwed the pooch somewhere, car runs, pops, did not mess with distributor timing. my wiring now is(from coil/power/tach connections area, going clockwise) 6-1-2-7-5-4-3-8. i'm flamboozeled, . if I have the wiring right, will have to go back and check wires. Help!!!
ankerclanker is offline
Old September 1st, 2018, 12:06 PM
tmaleck's Avatar
counter clockwise rotation. 1-8-4-3-6-5-7-2
tmaleck is offline
Old September 1st, 2018, 12:26 PM
Which is even cast into the intake manifold.
Old September 1st, 2018, 01:14 PM
plug wiring
Ok, tried running plug wires as you guys said, no start, no fire, reversed the wires, pop from carb. this is an HEI dist(ii was told that made a difference as to where wires were in relation to the tach/batt connections. Looking at the engine from the front. #8 wire is 1st contact behind the tach/bat connection followed by #3, #4, #5, #7,, #2, #1 and #6 is next to the tach/bat connection terminals. I must be dense, car starts but runs like crap.
at a loss here. thanks for help and understanding
Old September 1st, 2018, 03:03 PM
The most important thing is that you MUST figure out where No. 1 terminal is on your cap for the orientation of the distributor in the engine. The factory location of No. 1 is meaningless unless you have the distributor in exactly the same place as it was when it left the factory. The location of No. 1 relative to the BATT/TACH terminals is IRRELEVANT. All that matters is location relative to the rotor. Once you get that right, wires go 1-8-4-3-6-5-7-2 from there, CounterClockwise.
Old September 1st, 2018, 04:36 PM
v8al's Avatar
1972 CSM shows distributor and wires installed as follows: 1972 Oldsmobile distributor orientation
v8al is offline
Old September 1st, 2018, 05:33 PM
BillK's Avatar
ac,
Pull out the number 1 spark plug. (drivers side front) Hold your finger in the spark plug hole and have someone bump the starter until you feel air start coming out of the plug hole. Then continue turning the engine over until your timing mark on the harmonic damper is exactly at "0" Pull the distributor cap and see where the rotor is pointing. That should be the number one spark plug wire location. From there go counterclockwise 1-8-4-3-6-5-7-2
BillK is offline
Old September 1st, 2018, 06:46 PM
Here is the spark plug wiring positions for an HEI. The Batt/Tach terminals are between 2 and 7 in the cap and the square part is pointing to #7.
Old September 2nd, 2018, 12:35 PM
Got to say thanks again to all that responded to my question. Thanks guys, car running good now. Anyone know numbers for the power ball? just asking.
ted
Old September 2nd, 2018, 01:15 PM
Just an FYI, the stock timing settings for your are N/A with the HEI as the mechanical advance is different than a points distributor.
JustaOlds350
July 24th, 2017 07:19 PM
PHILATLAS
April 7th, 2017 08:36 AM
65droptop442
January 8th, 2013 09:26 AM
Magna86
April 16th, 2012 01:47 PM
silverriff
April 14th, 2008 07:00 AM
Quick Reply: spark plub wiring for HEI on a 65 330
