1971 350 water pump
Old August 29th, 2018, 10:00 PM
Mossy's Avatar
1971 350 water pump
What’s the general concensous for a replacement? As far as I know mine is working fine but it’s a rust bucket. 71 Cutlass s with factory A/C; although somewhat removed.
Mossy is offline
Old August 29th, 2018, 10:06 PM
Gascoop's Avatar
If it's working ok then take it off and use a rotary wire brush and some type of rust remover. Give it a good rattle can paint job, color of your choosing and re-install. Now if it's shot then buy a Flow Kooler aluminum pump of the correct length, no more rust and it's an outstanding pump ..... $115 at Summit racing.
Gascoop is offline
Old August 30th, 2018, 06:31 AM
Mossy's Avatar
Thanks for the info. I think I’m going to replace it due to not really knowing the history and being as I recently purchased the car, I haven’t driven it much
Mossy is offline
Old August 30th, 2018, 07:07 AM
Allan R's Avatar
That pump has already been replaced likely not too long ago judging by the patina. There are lots of parts on your car you won't know the history of but you likely won't replace them. Take the pump off and check the impeller side. IF it's all crudded up then it can be cleaned or replaced.If it looks fine, clean the outside, paint it and reinstall with a new gasket. If it's not broke, don't fixit. I'd check the radiator to see if there's scaling deposits in there too.
Allan R is offline
Old August 30th, 2018, 01:11 PM
As Allan said, you don't know the history of the engine, transmission, differential, etc but are you planning to replace them?
Fun71 is offline
Old August 30th, 2018, 03:18 PM
Mossy's Avatar
I’ll look it over thanks.
Mossy is offline
Old September 3rd, 2018, 09:33 AM
Mossy's Avatar
I got it removed last night and the impeller looks good and clean; outside and bolts have a good caking of rust. Also pulled the Tstat housing and looks like my Tstat is stuck closed.
Mossy is offline
Old September 3rd, 2018, 09:46 AM
Allan R's Avatar
Clean and paint the water pump; reinstall. Replace the T-stat and you should be golden. Sometimes the good fix isn't the most expensive.
Allan R is offline
Old September 5th, 2018, 09:36 PM
Mossy's Avatar
I was able to take a wire wheel to the pump and it cleaned up real well; just surface rust. Replaced the Tstat and the housing
Mossy is offline
Old September 10th, 2018, 02:11 PM
Mossy's Avatar
I went to torque all the bolts but one on the bottom decided to spin at the recommended 13 ft lbs. I tried using the other same sized bolts with the same results.
Are the smaller 1/4” bolts at the bottom of the pump just going through the timing chain cover or all the way through to the block?
Mossy is offline
Old September 10th, 2018, 02:43 PM
Those bolts thread into the timing cover.
Fun71 is offline
Old September 10th, 2018, 06:55 PM
Mossy's Avatar
great thanks. Unfortunately I just got the balancer and pump installed
Mossy is offline
Old September 11th, 2018, 04:40 AM
Water pump looks good, use some high temp clear coat to keep the rust away.
olds 307 and 403 is offline
Old September 11th, 2018, 06:59 AM
Allan R's Avatar
Which is why I said ^^^
Allan R is offline
Old September 11th, 2018, 07:51 AM
Mossy's Avatar
since it looks like I’ll have to take it back off that’s likely what I’ll do. Any specific brand I should look for? Thanks for the tip
Mossy is offline
Old September 11th, 2018, 09:19 AM
Allan R's Avatar
Water pumps were typically painted the same color as the block.
Allan R is offline
Old October 2nd, 2018, 01:36 PM
akspeedy's Avatar
Do you happen to know the correct length? they list part #1775 5-9/16" and part #1776 6" i am wondering as I need to replace my water pump on a rebuild. Thanks.
akspeedy is offline
Gascoop
June 15th, 2018 12:24 PM
Mike Sundy
August 11th, 2016 07:34 AM
Mr Shifty Sidney
January 5th, 2016 08:35 PM
DJS70cutlass
June 29th, 2015 08:52 AM
Cobrar980
April 22nd, 2012 05:05 PM
Quick Reply: 1971 350 water pump
