Muncie 4 Speed Reverse Light Switch - specific to car or trans?
Old August 27th, 2018, 08:22 PM
olds70supreme's Avatar
I have a 68 Cutlass that was an auto-->manual swap before I got it. I have the trans out now, and it doesn't have a reverse light switch on it. Are the reverse light switches specific to the trans, or to the car? Or in other words, do I buy a reverse light switch kit for a '68 Cutlass, or for whatever year the trans was built (need to confirm this).
Thanks.
olds70supreme is offline
Old August 27th, 2018, 08:40 PM
edzolz's Avatar
Back-up light switch is specific to Muncie four speeds not car model. there is a bracket that bolts to the side cover, a switch that bolts to the bracket and a rod that attaches from the switch to the reverse shifter arm on the transmission. Then you need the wiring harness from inside the car to the switch. I think these parts are available from aftermarket suppliers.
edzolz is offline
Old August 28th, 2018, 04:43 AM
35tac's Avatar
I replaced my backup lights wiring and switch on my 66 Cutlass this spring. Lectric Limited has everything you need to upgrade your Muncie 4 speed setup. Well made stuff and excellent customer service. Check out their web site.
Wayne
35tac is offline
Old August 28th, 2018, 06:57 AM
edzolz's Avatar
Wayne
Searched their website and could not find this setup for a Muncie. The only one listed is for a column shifted automatic.
edzolz is offline
Old August 28th, 2018, 07:37 AM
Since these switches are common with Chevy, EVERYONE sells repros.
Old August 28th, 2018, 07:45 AM
ben442's Avatar
got mine from Fusick, works great.
ben442 is offline
Old August 28th, 2018, 08:47 AM
35tac's Avatar
B/U light switch.
B/U Lighht switch 0199361 4 speed and B/U Light switch extension harness 4 speed 11130. should do it.
Wayne
35tac is offline
Old August 28th, 2018, 03:57 PM
Thanks for the info.
In the picture of the trans above, what is the plug/switch right under where the lead shift linkage mounts to the trans?
Old August 28th, 2018, 04:04 PM
The pigtail coming off the switch. The wires are just coiled up.
Old August 28th, 2018, 04:59 PM
I'm looking at the left-most shifter linkage - just under it is what looks like a hex w/ a plug sticking out from the bottom of it. Not the reverse light switch, which is near the middle shift linkage.
Old August 28th, 2018, 05:32 PM
Ah, this trans must have been from a car with Transmission Controlled Spark.
olds70supreme
September 4th, 2018 06:35 AM
35tac
Transmission
September 25th, 2017 01:24 PM
Oldracerjones
February 8th, 2014 11:03 AM
Dokks74
November 21st, 2011 11:18 AM
bryndalfly
Transmission
June 2nd, 2010 07:36 AM
Quick Reply: Muncie 4 Speed Reverse Light Switch - specific to car or trans?
