Complete CTS-V/ZL1 Brembo Brake system including calipers, rotors, adapter brackets
SOLD! - CTS-V/ZL1 Brembo Brake system including calipers, rotors, adapter brackets
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/bc61a8d4_e859_436b_8da8_c7488e8f995a_fdcaaeb4e91a02957f1347e2e079f91d1db83d0a.jpeg)
![](https://cimg0.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1500x2000/d135226e_498a_46dc_a7d7_7902db145c8e_3f741afef43545743147f3ebefa56e80db6406c4.jpeg)
![](https://cimg3.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/9e3f8967_b9ce_4149_b094_415b03b595e7_9093ca002798d5db1d72f92d5a9ba09a4f59fc02.jpeg)
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/1500x2000/89a11621_3b44_4cfa_91eb_40020abd6cb3_c981887cb30dc2a265f5eb5b771f55a293fdac5b.jpeg)
![](https://cimg7.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/a2bce632_83e9_4cd8_bbee_a4dbdce5bf69_191644a17ff918f927ddc12ac23bd96c0612ee3f.jpeg)
![](https://cimg1.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/52586e3b_c3c8_4043_9555_f6d967c65cc5_ec48f505ec944d621fd6fcae6d32678d510d31a2.jpeg)
Complete CTS-V/ZL1 Brembo Brake system (6 Piston front, 4 piston rear)including calipers, rotors (15 inch rotors front and rear), adapter brackets for GM A body front and 10/12 bolt housings (and 64-later Olds housings)
All parts are located in Denver (Lakewood to be exact), pics are in the next several posts
Hello all,
We are going a different route with our 1967 Cutlass build and it will unfortunately require selling all of our Brembo brake parts that we had accumulated.
These calipers are from a 2014 Cadillac CTS-V with only 40,000 original miles, and there are very few nics or minor scratches. They aren't new, but they are in very nice used condition. These are the same as the ZL1 Camaro calipers, but they are painted silver instead of Black.
These are the very large 6 piston front calipers and rear 4 piston calipers. I am including one brake line for a front caliper, and both of the rear caliper brake lines. I am also including the used factory Ferodo brake pads( probably 1/3 to 1/2 life left, hardware, and anti-squeal clips).
Average cost I have found for nice used CTSV calipers is about $1200
As for the Rotors,these are the huge 15 inch rotors. They are the upgrade versions (versus a CTS-V) all from a 2015 Camaro ZL1, with the two piece front rotors with the aluminum hat centers and the rear iron rotors. They have very little wear on them at all, with only 5,000 street miles on them, and they have no flaws or issues to speak of. One of the front rotors has some very minor discoloration of the rear surface because of some light surface rust that was easily cleaned with a scuff pad. These rotors do work perfectly with the CTS-V calipers (which are the same as the ZL1, but painted silver).
average cost on these is $800 for nice used ones
Also pictured are the LSX CONCEPTS BREMBO caliper adapter brackets for the 6 piston front Brembo calipers for both the CTS-V and ZL1 caliper models.
Cost $299
We also have the FLYNBYE brackets (not yet pictured because they are still on the axles for now- we will pull them off in the next day or so) http://www.flynbye.com/catalog/i238.html
Cost $90 + Shipping
Also included but not pictured (yet) are the Wilwood 270-7037 hubs with 1/2 Strange studs- machined O.D. for locators -
cost over $280
All of the bolts you will need for this setup are also included.
REPLACEMENT COST AVERAGES:
used Caliper set - $1200
used Rotor set - $800
LSX Concepts adapters - $299
Wilwood hubs and studs - $280
Flynbye brackets - $100
Bolts and hardware included
________________________________
Over ~$2,700 total low replacement cost estimated value
We are asking $1,850 + Shipping at cost for the entire brake setup, minus the off the shelf 270-7037- Wilwood hubs and studs (calipers, rotors, LSX Concepts front 6 piston Brembo adapters, FlynBye rear Brembo adapters)
Separately, the parts are listed/priced as follows:
Front and rear CTS-V Brembo Calipers (6 piston fronts and 4 piston rears) - $1,000 + shipping at cost
ZL1 Rotor set - $650 + shipping at cost
LSX Concepts Front Brembo 6 piston adapter bracket kit - $230 shipped to Con. USA
Flynbye rear Brembo adapter brackets for GM 10/12 bolt rear housings - $80 shipped to Con. USA
Do not be afraid to make an offer. Also, Note that Wilwood Big Brake kits are over $1500 just for the front brakes.
call or text me if interested in complete or partial kit. Also for sale locally.
72zero-27two-575six
Aceshigh
Brakes/Hydraulic Systems
September 5th, 2009 06:34 AM
