Intake manifold
Intake manifold
I’m new to this forum as well as engine rebuild. I was always working on body work but want to start learning about motor work. I have a 68 Olds Supreme 350. I want to replace the intake manifold do I need to take out the distributor? Looking at the manifold doesn’t look like I need to but want to make sure before I do any damage to the motor during or after the manifold is installed
Carb hook up
So finally got the the intake / carb installed. The problem I’m having now is the throttle cable is way bigger than the ball stud. I really don’t see a ball stud that big that will screw into the carb. Any suggestions?
Looks like I have to purchase an after market bracket for the cable as well. If I use the original cable bracket the cable isn’t straight. Any suggestions???
its a Edelbrock manifold and Edelbrock carb 1406.
Thank guys.
Thank guys.
Ricko442
May 19th, 2018 05:16 PM
