What have you done to your Oldsmobile today
Old March 25th, 2018, 09:42 AM
  #1681
HX3
HX3's Avatar
Hmmm ... 7, 8 or 13 ... went with Lucky 7!
HX3 is offline
Old March 25th, 2018, 11:12 AM
  #1682
SWinner's Avatar
Rebuilt Power Steering Gear Box
Last weekend I noticed that the steering box was leaking fluid from the end (toward the front of the car) of the gearbox. I studied the CSM, watched a few U-Tubes and ordered the rebuild kit. I've never rebuilt one of these. I was surprised to see how dirty it was inside. Cleaned everything, proceeded one step at a time. Putting the recirculating ***** back in took several try's, but I got it back together. Now I need to readjust the steering wheel.
Another rebuild to add to my list.
SWinner is offline
Old March 31st, 2018, 10:42 PM
  #1683
Phantom Phixer
Charlie Jones's Avatar
I painted the bottom side of my 394 , Ford red .
Charlie Jones is offline
Old April 1st, 2018, 05:21 AM
  #1684
dennis_30281's Avatar
Paint
Maybe orange????
Dennis
dennis_30281 is offline
Old April 1st, 2018, 10:22 AM
  #1685
Phantom Phixer
Originally Posted by dennis_30281
Maybe orange????
Dennis
Ford red does have an orange tint to it . It has been purported to be an almost exact match to the original Olds paint .
Old April 1st, 2018, 03:43 PM
  #1686
Orange
I'll keep that in mind.
Dennis
Old April 2nd, 2018, 04:03 PM
  #1687
344879M363895
70-442-W30's Avatar
Well, I currently have no Oldsmobiles. But I thought about the W-30 today...a lot. The journey, the people, the history, and the man. I do miss the car, I'd be lying if I said I didn't.
Strange what a car can do to your life. Met some cool people. Had a few fun rides in it. Took some great pictures. Learned a little about the history of Oldsmobile. And made a little history of my own.
At the end of the day, I'm not sure if I'd do it any differently. It wasn't easy, but it sure was amazing. And I'm lucky to even have had that experience. Just really lucked into what some hear have searched for years for and haven't found. So I'm really grateful for that. And again for all the help along the way.
Now back to what you've done to your Oldsmobiles today.
70-442-W30 is offline
Old April 2nd, 2018, 04:18 PM
  #1688
RonFX's Avatar
66 Cutlass
Getting ready to send it out to get A Complete Overhaul of the rear end, It has a Factory 4:10 posi unit in it now, but I am changing it out to a 3:42 Posi Setup. I bought all the parts from a fellow member. I bought the following:
Yukon 3 series clutch type posi carrier
Yukon 3:42 ring & pinion
Complete bearing & seal kit for everything
Yukon Axle Assemblies
Everything but the housing replaced.
I've had the car since 1975, kind of sentimental.
RonFX is offline
Old April 2nd, 2018, 05:24 PM
  #1689
35tac's Avatar
Nothing. It's still in storage. It snowed this morning and the last fifteen day forecast shows thirteen days of rain and it starts in the morning. Sucks.
35tac is offline
Old April 4th, 2018, 07:42 PM
  #1690
zeeke's Avatar
Took the Cutlass on a 40 mile round trip to the LI & NYC Olds monthly meeting. Any excuse is all I need.
zeeke is offline
Old April 5th, 2018, 06:59 AM
  #1691
HeavyOlds's Avatar
I wish I could jump this high off the starting line.
About to rebuild the front end. Tubular uppers, cross drilled and slotted rotors, new powder coated calipers with steel braided lines and ceramic brake pads. QA1 adjustable shocks. I'm replacing the weak Moroso trick drag springs with some MOOG 6204 units. I'm hoping that will lift my front end a bit higher and still give me a bit of a drag spring effect.
HeavyOlds is offline
Old May 9th, 2018, 02:54 AM
  #1692
deadeyejedi's Avatar
last two nights after work i installed 4 new shocks ,upper ball joints ,sway bar end links, and sway bar bushings in the 80 cutlass supreme.what a difference in handling! need a rear sway bar to tighten up the back end .
deadeyejedi is offline
Old May 31st, 2018, 08:06 PM
  #1693
just rust's Avatar
Been a long time since I have posted anything up. Installed a hidden stereo system, mounted some gauges, almost have the interior finished up, figured out my brake issues with front disc conversion (push rod length), installed blinker switch and lever, plugs and wires and most importantly got it out on the road for the first time this year, today! Here it is in it's spray bomb glory:
just rust is offline
Old May 31st, 2018, 08:25 PM
  #1694
whiskey runner's Avatar
cool car..
whiskey runner is offline
Old June 2nd, 2018, 10:42 AM
  #1695
Frank Ignachuck
ignachuck's Avatar
Shined up the A/C plumbing on the '56 Super 88:
ignachuck is offline
Old June 2nd, 2018, 06:05 PM
  #1696
delete
droptopron's Avatar
Vapor locked it but got it started. Hot day today, low 90's i think
droptopron is offline
Old June 3rd, 2018, 06:41 PM
  #1697
Local Hero's Avatar
Got my wife's Vert into the shop finally. Got it up in the air for an oil change a greased the front end. Also prepared for the paintless dent removal guy to come this week and fix the boo boo I put in the rear quarter when parking it last winter.
Local Hero is offline
Old June 27th, 2018, 08:50 PM
  #1698
Phantom Phixer
fuel pump
I rebuilt the fuel pump for my '63 Dynamic . $45 for a kit and $5 for an old stock filter .
Sure beats sending it off somewhere to have it rebuilt for $350 .
The old ;
The new ;
Some of the in progress shots ;
Old June 28th, 2018, 04:17 AM
  #1699
looks good.. save money and get the pleasure knowing you did it yourself..
Old July 1st, 2018, 07:11 PM
  #1700
Tedd Thompson's Avatar
A limb/ small log was left by either a wood cutter or fell off a logging truck and I had the misfortune to nail it with the 55.It tilted up like a hockey stick and smashed my passenger side rocker molding, almost took it off the side of the car. Today was the try and remove the dent and straighten the bend in it and re attach it day. It's on there but I'm not sure I can live with it yet. Wrinkles are a bitch on a chrome strip to hide.
The last time I replaced those moldings it took two years to find NOS units and cost a kings ransom.Does anyone know why the rocker panel moldings listed in the Fusick Catalog (#566338/9 same number for both models) will fit a super 88 and a 98 when there is 8 inches difference in length? Doesn't seem right. Just call me tin bender from now on..... Tedd
Tedd Thompson is offline
Old July 1st, 2018, 08:57 PM
  #1701
Proud Viet Nam Veteran
redoldsman's Avatar
Tedd, that just sucks. I don't have the rocker panel moldings on my 54. They were so bad that they were just removed during the restoration. I have heard that NOS ones of near impossible to find and as you mentioned cost the kings ransom. Have you ever measured ones for a tri-five Chevy? I imagine Danchuks or Ecklers reproduces them.
redoldsman is offline
Old July 1st, 2018, 09:13 PM
  #1702
47 Convertible's Avatar
Tedd, I'm just guessing its stainless that got dented. If so there are people in plating shops who can make bent, dented, scraped stainless look new. Ask around. I had my rear bumper straightened and rechromed on the 47. It was done by Stockton company: https://www.westcoastchrome.com/ They had another shop in town that they work with to straighten weld and grind bumpers and then West Coast does the plating. The price was the best of several shops estimates, they were easy to work with, delivered the bumper back in just a few weeks. I was very happy with them. I think they do stainless, but you would have to ask. In my case I sent some photos so they could see the bumper and guards before they estimated cost.
ps. Couldn't this be an insurance claim? Surely it goes above whatever your deductible is.
Jerry
47 Convertible is offline
Old July 1st, 2018, 09:26 PM
  #1703
Red, ya it almost made me sick when it happened (did make me mad) Damn stick was right in the middle of the road but in a shaded area and I was in direct sunlight, didn't see it till I hit it at about 25 miles an hour.
The Chevy thing might be a option but just looking at them I would think the Old's would be longer.
I'll give Fusick a call tomorrow and ask about the 88 and 98 number being the same, Who Knows could be a misprint.
Though my car has been a driver most of it' life it's starting to look like it more and more......Tedd
Old July 1st, 2018, 09:40 PM
  #1704
Jerry I have 0 deductible so it shouldn't cost me anything I don't think unless there is a bitch for me taking it off and working on it already.
If Fusick has them and they are the correct length and look good that would be the way to go. My catalog shows them at $210 for repops and that would be a good price. The last set of NOS I found took two years to find and that was about 10 years ago, fat chance I'll find a set again.....Tedd.
Old July 2nd, 2018, 06:23 AM
  #1705
Olds442redberet's Avatar
I installed new carpet
Olds442redberet is offline
Old July 2nd, 2018, 08:32 AM
  #1706
Phantom Phixer
Tedd, my 1960 Olds parts book lists part #566338/9 as fitting all 1955 Super 88s and 1955 98 four door sedans .
1955 98 hardtop coupes , hardtop sedans and convertibles took a different number 566340/1
Old July 2nd, 2018, 09:38 AM
  #1707
delete
droptopron's Avatar
Which car is that (obviously not the 70)? Looks good.
Old July 2nd, 2018, 07:40 PM
  #1708
65B01Delta's Avatar
I started mine and moved it around some....
65B01Delta is offline
Old July 5th, 2018, 07:29 AM
  #1709
ELY442's Avatar
I replace the actuator located under the dash towards the firewall. If your mechanically inclined, this job is not a problem. If not, bring it to a mechanic shop and let them break their back by doing this job. You need to recalibrate the HVAC system by pulling the fuse out (located under the driver side rear seat). First you need to start the car up and set the a/c mode to "Auto" and then turn your car off, pull the fuse out, remove and replace the actuator, install the fuse and start the car up for 2 minutes while the a/c recalibrate (the a/c will say 72* on the display), turn the car off for 10 seconds, start the car up and go thru all the modes (defroster, vent, heater).
2002 Bravada, this actuator controls the air flow to the defroster and heater.
As you can see the crack, I had a problem of getting no air flow to the heater. No matter what buttons I pushed, the air flow goes to the defroster and vents. When I turned on the a/c, the cold air will fog up the outside of the windshield and I had to use the wipers to wipe it off. Its a pain in the *** to drive on a hot humid day with the a/c on and your windshield fogs up your vision.
ELY442 is offline
Old July 8th, 2018, 10:27 AM
  #1710
budg's Avatar
Well I finally got around to doing basic maintenance that should have been done earlier in the year. I changed the fuel filter, cleaned the air filter , changed the oil and gapped and changed the spark plugs. The plugs looked ok. Nothing scary other than normal carbon build up. I dont know when they were changed last. It runs great . New plugs make this thing idle really smooth.
budg is offline
Old July 12th, 2018, 12:42 PM
  #1711
35tac's Avatar
Took delivery today on 4 P215/70R14 BFG Silvertown Redline radials to replace the current 11 year old redlines. Boy did that hurt.
Wayne
35tac is offline
Old July 12th, 2018, 01:09 PM
  #1712
bassinguy's Avatar
What have you done
Just put my car on a 6 week minimum vacation. I just broke my left fibula(ankle bone) ,nice diagonal break. No weight bearing for 6 weeks ,then possible usage after that. Hard to shift with cast on and no bending of ankle. Could be worse Have a good day all. Bassinguy
bassinguy is offline
Old July 12th, 2018, 04:47 PM
  #1713
I did a nice smokey burnout. 😎
matt69olds is offline
Old July 13th, 2018, 05:43 PM
  #1714
maddoctor's Avatar
Fitestones
Originally Posted by oldstata
I pulled the trunk scrip and rear extension housings block sanded left quarter , DA left door and trying to finish up right quarter
Attachment 167540
I drove mine to work.
Attachment 166339
Nice 68 look with 2018 ride
Cool tool box i picked up
maddoctor is offline
Old July 13th, 2018, 05:45 PM
  #1715
maddoctor's Avatar
Holley sniper goes on next week, can't wait.
Old July 13th, 2018, 08:25 PM
  #1716
Phantom Phixer
Re-built the carb for my 394.
Carb rebuild kit from O'Reilly's on Mastercard $29.95 .
Doing it myself ; Priceless !
Old July 14th, 2018, 11:12 AM
  #1717
ben442's Avatar
Stripes back in place
ben442 is offline
Old July 14th, 2018, 12:46 PM
  #1718
Lsx442's Avatar
Started installing a new carb on the 69 early this morning. The last time I drove the car I was running really bad and wouldn’t idle. The old QJet needs to be rebuilt but I don’t have time to mess with it right now. I need to to finish bending up a new fuel line and wire up the electric choke.
Lsx442 is offline
Old July 15th, 2018, 04:14 PM
  #1719
carbizguy's Avatar
photo op
just shined up the 63 and took her for a cruise
carbizguy is offline
Old July 19th, 2018, 08:34 PM
  #1720
Tymiles24's Avatar
330 rebuild
putting in the brackets...manifold is on!!!
Tymiles24 is offline
Quick Reply: What have you done to your Oldsmobile today
