Location of "os" sticker on '69 4-4-2 air cleaner
So, I've got my brand new "Keep your GM car all GM" sticker from Chris for my '69 4-4-2 and now I don't know where it is supposed to be applied! If any of you have a picture, or dimensions, on where it is supposed to go, please let me know so I can put it on!
I had originally intended to apply it 180 degrees out from the snorkel, much like the silk screening that went on my '68 4-4-2. The '69 A-body PIM seems to show differently, though. Manual Section 6-1 page 151 indicates the sticker should go about 90 degrees clockwise from the snorkel as you look down from the top of the air cleaner assembly.
I put out some feelers but got only one response. Before I apply this sticker, I'm hoping to get a consensus of where it is supposed to go. If someone had measurements of where it goes, and even perhaps a picture of their original sticker, that would be the best!
If it makes any difference, my '69 is a Fremont car.
Thanks in advance!
Randy C.
Thanks in advance!
Randy C.
That is perfect! Thank you so very much! It makes sense that it would be in a place where people could see it when they open the hood. The PIM seems to put it in a place where it just wouldn't be seen. Thanks again!
Randy C.
Randy C.
I just measured out my air cleaner for the OS sticker, based on what Trophyblue442 said. From the snorkel (actually, the snorkel flange, which is only about 1/8" from the snorkel) to what appears to be the center line of my air cleaner assembly is pretty close to 7 1/4". So, with the OS sticker starting at 10 3/4" from the snorkel, the sticker is closer to the center line than the snorkel. I understand the reasoning for the sticker to be equidistant from the center line as the snorkel (balance), but I can also see a reasoning that GM would want that sticker fully exposed and perhaps that's why the sticker is closer to the center line, than more to the side, of the air cleaner assembly.
Good question for the W cars posted by Boiler_81!
Randy C.
Randy C.
razziz
February 6th, 2013 01:56 PM
