65 cutlass 442 pvc tube
Old June 19th, 2018, 05:12 PM
brandon reynolds's Avatar
For sale is a 1965 442 or cutlass PCV tube that has been blasted and repainted the correct original rubber hose with the five ribs in it. The correct spring clamp. And the original crank case breather. As far as I know the breather tube has not been reproduced. Out of the 7 65s at the nationals none of the ones I saw had this piece installed. $150 shipped to your door. Thanks
brandon reynolds is offline
Old July 29th, 2018, 04:47 AM
Bringing these to the nationals if anybody’s interested. Thanks Brandon
Old July 29th, 2018, 07:01 AM
classicmuscle442's Avatar
Would this be used on just the automatic '65? My stick car has a breather/cap on the oil fill tube.
classicmuscle442 is offline
Old July 29th, 2018, 12:29 PM
Good question. My car is an auto, do you have a hole on your air cleaner snorkel for this to go to?
Old July 29th, 2018, 06:36 PM
No, car has an open air cleaner not the larger chrome looking air cleaner with a snorkel. Thought the four speed cars came with the open air cleaner, have had the car since '75 but could have been changed. Base of air cleaner has the drop down base. Car was built in August and had a pvc valve in valve cover.
Old July 29th, 2018, 06:38 PM
Chris they never came with an open element air cleaner. I’d say your original one is missing. When I was just at the homecoming in Lansing, six of the seven 65s there didn’t have the original air cleaner.
Old July 29th, 2018, 08:07 PM
Thanks did not know that. Know there were late changes near the end of 65 442 production, few tri carb experimental intakes were made, same casting number as 66 but with an X after it, still learning. Sorry did not mean to hi-jack your thread.
Old July 30th, 2018, 05:25 PM
Gerald Nickels's Avatar
442BRO shows the 65 tri-power Ex.-
I have a NOS one but no tube or hose or clamp.
Gerald Nickels is offline
yorkman
September 27th, 2019 06:23 PM
brandon reynolds
March 3rd, 2019 10:18 AM
Gerald Nickels
January 25th, 2019 03:33 PM
brandon reynolds
July 2nd, 2018 08:19 PM
Christopher Michael Drew
March 30th, 2018 07:48 AM
Quick Reply: 65 cutlass 442 pvc tube
