Wanted - 1969 Cutlass 442 convertible Torque Box
Old May 7th, 2018 | 09:20 AM
fiebs442's Avatar
Looking for the passenger side torque box in good shape. Understand this is larger than the reproduction torque boxes sold online.
Old May 7th, 2018 | 11:28 AM
442crzy's Avatar
PM sent
Old May 7th, 2018 | 11:38 AM
ROCKETMAN269V's Avatar
I'm not 100% sure that they are the same, but I have the firewall area from a '70 442 convertible. I will separate. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old May 7th, 2018 | 02:26 PM
Great pic. Unfortunately, mine is different. Good luck with your search.
Old May 7th, 2018 | 05:11 PM
442crzy's Avatar
Mine are different as well, good luck with your search.
Old May 8th, 2018 | 07:13 AM
cdrod's Avatar
Rodney
The Parts Place sells a double mount, torque box. Here's a link to his eBay listing for a pair:
https://www.ebay.com/itm/1968-72-A-B...cAAOSw4CFYpMP9
Old May 8th, 2018 | 09:29 PM
fiebs442's Avatar
Thanks. I think that double mount box is what I am looking for.
Old May 9th, 2018 | 06:57 AM
allyolds68's Avatar
This is a 68. 69 should be the same. Single mount. Check your 69 assembly manual for sure
Old May 9th, 2018 | 07:40 AM
That's what my '70 442 convertible firewall looks like. also.
Old May 9th, 2018 | 08:40 PM
fiebs442's Avatar
I appreciate all the feedback and help. I could not find anything in the assembly manual. I did find in the illustrated parts book on page 12-122 what they call a brace assembly. The pictures provided for the drivers side looks exactly like mine. I have come to the conclusion that the passenger side toe board I am putting in and the repo brace I already had purchased is correct and just needs some fitting. So the double mount appears not to be correct. Thanks again for all your help.
Old May 10th, 2018 | 05:25 AM
allyolds68's Avatar
This is from the 68 Assembly Manual. It's very generic but it definitely shows one mount
Old May 10th, 2018 | 08:17 AM
oldspackrat's Avatar
I have owned a bunch of convertible parts cars & I don't remember Olds. ever having the double mount at the front. I think I've seen Buicks & maybe Chevies that have had them.
Old May 10th, 2018 | 12:36 PM
fiebs442's Avatar
I think the consensus is "no double mounts on the olds". I do wonder why some of the other cars with the same A-frame had double mounts? Interesting.
Old May 11th, 2018 | 10:02 AM
Eightupman's Avatar
These are from a 1972 Supreme if you can use them. Just need to weld the square nut back in... (I have them somewhere... not stripped)
Make offer if it will work.
John
Old May 11th, 2018 | 08:10 PM
2blu442's Avatar
Well... I wonder if this is one of those things that varied by assembly plant? Here's some pictures of a 1968 and it has two holes. But looking at the rust marks it looks like only one bolt was installed.
Old May 11th, 2018 | 08:50 PM
marxjunk's Avatar
that double mount is on many buicks and oldsmobile 69 up..it controls cowl shake...and thats why its there on upper end buicks and olds...
chevy and pontiacs used the single mount..thats what ive seen..even some buick hardtops use the big mount..it may not have the bolt in it..it may use a dummy mount..but ive seen it..especially on 4 door skylarks..i have 3 cars ready to crush..let me see if theres anything on them usable..including a 4 door hardtop..good chance it has it...
Old May 12th, 2018 | 08:20 AM
fiebs442's Avatar
Interesting discussion. However, I no longer need this part.
crystal59
July 6th, 2023 05:39 PM
coppercutlass
Body work
March 25th, 2014 06:40 AM
halfmoontrail
March 22nd, 2014 06:20 PM
halfmoontrail
August 31st, 2013 10:05 PM
davepnola
Chassis/Body/Frame
September 11th, 2011 12:23 AM
