1970 w-31
Old April 15th, 2018, 02:53 PM
19684424speedconvertible's Avatar
1970 w-31
I bought a 1970 Cutlass W-31 last weekend. 42,844 miles,numbers matching engine, JO transmission, and TO code rearend. Very happy,I finally own a real Olds W machine !!
19684424speedconvertible is offline
Old April 15th, 2018, 02:56 PM
Old April 15th, 2018, 03:01 PM
Old April 15th, 2018, 03:02 PM
Old April 15th, 2018, 03:06 PM
Old April 15th, 2018, 03:08 PM
My442's Avatar
Thumbs up
Very nice!
My442 is offline
Old April 15th, 2018, 03:23 PM
Currently has an 11 to 1 compression solid lifter cam race engine in it with a 4.66 gear posi in it. But I have the original numbers matching engine. It is a great survivor car,slightly modified but still VERY original. Hope to have the old girl back on the road next summer.
Old April 15th, 2018, 03:25 PM
geardoc66's Avatar
Everyone on the site (including me) has been ogling that car, glad to see someone picked it up. Congratulations!
geardoc66 is offline
Got the original engine,exhaust manifolds,aluminum w-350 intake with it. Original trans and rear still in car. Just need original 1111975 distributor and 7040255 carburetor. If you have one please pm me.
Old April 15th, 2018, 04:19 PM
Wow, column shift so I guess front bench seat? It's amazing how the ultra-high performance cars back then could be had with the base level options, unlike today where the manufacturers price gouge you.
Fun71 is offline
Old April 15th, 2018, 04:33 PM
Ctls442's Avatar
Glad the car went to a good home.
Ctls442 is offline
Old April 15th, 2018, 05:06 PM
Me too !! I`m going to take good care of the old girl.
Old April 15th, 2018, 08:39 PM
Stefano's Avatar
Congrats, Kool W-Machine.
Stefano is offline
Old April 16th, 2018, 04:00 AM
Carshinebob's Avatar
Very cool car with docs and history. Keep us updated. ~BOB
Carshinebob is offline
Old April 16th, 2018, 07:44 AM
The base equipment for that car was a bench seat and a "Dearborn" HD three speed with Hurst floor shifter. If you ordered the optional automatic, you got a column shifter no matter if you had bench or buckets. If you wanted a console with buckets, you also had to order RPO D55. Cars were very much order-to-taste then. There were not the limited "packages" you see today, just a list of RPOs that you could pick and choose from. Manufacturers figured out that they could increase profits by limiting the variations on the assembly line, which is why today's cars come as package deals. It's just like "bundling" from your cable TV vendor.
Old April 16th, 2018, 09:51 AM
Escape From The Ordinary
WTHIRTY1's Avatar
Very cool W-Machine! Congrats on the purchase. I see you're in Michigan--will you have it up and running by Homecoming in June?
WTHIRTY1 is offline
Old April 16th, 2018, 02:03 PM
I love it, very cool!
Greg Rogers is offline
Old April 16th, 2018, 05:43 PM
Gerald Nickels's Avatar
I'll check on the 350 dist. You want the right date ?
Gerald Nickels is offline
Old April 16th, 2018, 06:00 PM
fasteddy's Avatar
Awesome. If I did not have a project I would have picked that one up myself. Great documentation on it!!
Pat
fasteddy is offline
Old April 17th, 2018, 09:19 AM
Yes if possible, car manufactured 3-70
Old April 17th, 2018, 02:55 PM
Probably not. I want to get new tires, flush gas tank and brake lines, repack wheel bearings, check brakes, misc, install new exhaust and go through engines to put one together for the street. Car currently has high octane racing fuel in it(no mistaking that stuff) and I`m not going to run an 11 to 1 motor that requires that stuff on the street. May or may not run it for a bit with the 4.66 gears in it before I change back to 3.91 gear. Don't want to do a rush job, plus I have another car partially apart that needs to go back together first.
Old April 17th, 2018, 06:04 PM
Runner
Joffroi's Avatar
awesome looking car!
Joffroi is offline
Old April 18th, 2018, 06:46 PM
damaged442's Avatar
I know I was checking that car out! Congrats on your new acquisition! Glad she went to a good home!
damaged442 is offline
Old April 19th, 2018, 06:38 PM
oldsmobiledave's Avatar
Awesome
Congratulations on the purchase and enjoy.
oldsmobiledave is offline
Old April 21st, 2018, 04:08 AM
budg's Avatar
Congrats. I love the silver with black striping combo. That is a beauty of a car .
budg is offline
Old April 21st, 2018, 05:53 AM
Put on a new differential gasket, new gear oil and posi additive, changed motor oil and filter and put in a new set of spark plugs and 2 gallons of 110 octane fuel yesterday. Had the rear cover off to verify rear gear ratio, yep 4.66.
Old April 21st, 2018, 02:58 PM
Shoveling Snow
Hairy Olds's Avatar
Daryl used to run all the way up into the 5s depending on the track.
Hairy Olds is offline
Old April 21st, 2018, 04:23 PM
5 series gears
To my knowledge the 5s include a 5.00 and 5.33
We're there any other 5 series race gears?
Old April 21st, 2018, 07:31 PM
The dist I have says 1111975 date code says I think OE27 or OF27 any body decode it.
Old May 12th, 2018, 12:45 PM
I have been able to purchase a correct distributor, water pump and carburetor for the car. Thanks everyone for your help.
Old May 14th, 2018, 05:57 AM
WTHIRTY1's Avatar
Nice! Congrats on procuring the correct carb.
WTHIRTY1 is offline
Old May 14th, 2018, 08:43 AM
Water pump and distributor......
Old May 20th, 2018, 06:54 AM
Disassembled the original engine over the last week. The engine appears relatively unmolested,except for 1 replacement piston. Has the big valve #6 heads,original W-31 cam, rods, balancer and all the casting dates on the block,heads,crank,pistons predate build date of car. Standard bore with no ring land felt at top of the cylinder. All the rods and mains were checked with plastigauge and I inspected all the remaining pistons for any damage. I have a new NOS W-31 piston to replace the incorrect one. Hard to know why one piston was changed as the owner that did it is deceased. The story I got was owner pulled the original engine to put in a engine to go racing with. My intent is to reinstall the stock engine with all the original factory correct parts and enjoy it the way Oldsmobile built it.
Old May 28th, 2018, 02:41 PM
alain's Avatar
Thumbs up w 31
Amazing W car
Alain
alain is offline
Old May 29th, 2018, 07:32 AM
sschevellecutlass_Bob's Avatar
Love it!! Noticed you have vent in window corner.... my 1970 Cutlass S does not have one......did they make both types of door windows in 1970?
sschevellecutlass_Bob is offline
Old May 29th, 2018, 07:39 AM
Sport Coupes (2dr post) used vent windows through the 1972 model year. Holiday Coupes (2dr HT) stopped using vent windows with the 1969 model year.
gearheads78
June 27th, 2013 12:33 PM
halfmoontrail
January 20th, 2013 05:46 PM
Nickyloves442s
October 24th, 2012 04:55 PM
charlierogers
October 14th, 2011 09:44 AM
Quick Reply: 1970 w-31
