1970 w-31
Old Apr 15, 2018 | 02:53 PM
19684424speedconvertible's Avatar
1970 w-31
I bought a 1970 Cutlass W-31 last weekend. 42,844 miles,numbers matching engine, JO transmission, and TO code rearend. Very happy,I finally own a real Olds W machine !!
Old Apr 15, 2018 | 02:56 PM
Old Apr 15, 2018 | 03:01 PM
Old Apr 15, 2018 | 03:02 PM
Old Apr 15, 2018 | 03:06 PM
Old Apr 15, 2018 | 03:08 PM
My442's Avatar
Thumbs up
Very nice!
Old Apr 15, 2018 | 03:23 PM
Currently has an 11 to 1 compression solid lifter cam race engine in it with a 4.66 gear posi in it. But I have the original numbers matching engine. It is a great survivor car,slightly modified but still VERY original. Hope to have the old girl back on the road next summer.
Old Apr 15, 2018 | 03:25 PM
geardoc66's Avatar
Everyone on the site (including me) has been ogling that car, glad to see someone picked it up. Congratulations!
Got the original engine,exhaust manifolds,aluminum w-350 intake with it. Original trans and rear still in car. Just need original 1111975 distributor and 7040255 carburetor. If you have one please pm me.
Old Apr 15, 2018 | 04:19 PM
Wow, column shift so I guess front bench seat? It's amazing how the ultra-high performance cars back then could be had with the base level options, unlike today where the manufacturers price gouge you.
Old Apr 15, 2018 | 04:33 PM
Ctls442's Avatar
Glad the car went to a good home.
Old Apr 15, 2018 | 05:06 PM
Me too !! I`m going to take good care of the old girl.
Old Apr 15, 2018 | 08:39 PM
Stefano's Avatar
Congrats, Kool W-Machine.
Old Apr 16, 2018 | 04:00 AM
Carshinebob's Avatar
Very cool car with docs and history. Keep us updated. ~BOB
Old Apr 16, 2018 | 07:44 AM
The base equipment for that car was a bench seat and a "Dearborn" HD three speed with Hurst floor shifter. If you ordered the optional automatic, you got a column shifter no matter if you had bench or buckets. If you wanted a console with buckets, you also had to order RPO D55. Cars were very much order-to-taste then. There were not the limited "packages" you see today, just a list of RPOs that you could pick and choose from. Manufacturers figured out that they could increase profits by limiting the variations on the assembly line, which is why today's cars come as package deals. It's just like "bundling" from your cable TV vendor.
Old Apr 16, 2018 | 09:51 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Very cool W-Machine! Congrats on the purchase. I see you're in Michigan--will you have it up and running by Homecoming in June?
Old Apr 16, 2018 | 02:03 PM
I love it, very cool!
Old Apr 16, 2018 | 05:43 PM
Gerald Nickels's Avatar
I'll check on the 350 dist. You want the right date ?
Old Apr 16, 2018 | 06:00 PM
fasteddy's Avatar
Awesome. If I did not have a project I would have picked that one up myself. Great documentation on it!!
Pat
Old Apr 17, 2018 | 09:19 AM
Yes if possible, car manufactured 3-70
Old Apr 17, 2018 | 02:55 PM
Probably not. I want to get new tires, flush gas tank and brake lines, repack wheel bearings, check brakes, misc, install new exhaust and go through engines to put one together for the street. Car currently has high octane racing fuel in it(no mistaking that stuff) and I`m not going to run an 11 to 1 motor that requires that stuff on the street. May or may not run it for a bit with the 4.66 gears in it before I change back to 3.91 gear. Don't want to do a rush job, plus I have another car partially apart that needs to go back together first.
Old Apr 17, 2018 | 06:04 PM
Joffroi's Avatar
Runner
awesome looking car!
Old Apr 18, 2018 | 06:46 PM
damaged442's Avatar
I know I was checking that car out! Congrats on your new acquisition! Glad she went to a good home!
Old Apr 19, 2018 | 06:38 PM
oldsmobiledave's Avatar
Awesome
Congratulations on the purchase and enjoy.
Old Apr 21, 2018 | 04:08 AM
budg's Avatar
Congrats. I love the silver with black striping combo. That is a beauty of a car .
Old Apr 21, 2018 | 05:53 AM
Put on a new differential gasket, new gear oil and posi additive, changed motor oil and filter and put in a new set of spark plugs and 2 gallons of 110 octane fuel yesterday. Had the rear cover off to verify rear gear ratio, yep 4.66.
Old Apr 21, 2018 | 02:58 PM
Hairy Olds's Avatar
Shoveling Snow
Daryl used to run all the way up into the 5s depending on the track.
Old Apr 21, 2018 | 04:23 PM
5 series gears
To my knowledge the 5s include a 5.00 and 5.33
We're there any other 5 series race gears?
Old Apr 21, 2018 | 07:31 PM
The dist I have says 1111975 date code says I think OE27 or OF27 any body decode it.
Old May 12, 2018 | 12:45 PM
I have been able to purchase a correct distributor, water pump and carburetor for the car. Thanks everyone for your help.
Old May 14, 2018 | 05:57 AM
  #31
WTHIRTY1's Avatar
Nice! Congrats on procuring the correct carb.
Old May 14, 2018 | 08:43 AM
  #32
Water pump and distributor......
Old May 20, 2018 | 06:54 AM
  #33
Disassembled the original engine over the last week. The engine appears relatively unmolested,except for 1 replacement piston. Has the big valve #6 heads,original W-31 cam, rods, balancer and all the casting dates on the block,heads,crank,pistons predate build date of car. Standard bore with no ring land felt at top of the cylinder. All the rods and mains were checked with plastigauge and I inspected all the remaining pistons for any damage. I have a new NOS W-31 piston to replace the incorrect one. Hard to know why one piston was changed as the owner that did it is deceased. The story I got was owner pulled the original engine to put in a engine to go racing with. My intent is to reinstall the stock engine with all the original factory correct parts and enjoy it the way Oldsmobile built it.
Old May 28, 2018 | 02:41 PM
  #34
alain's Avatar
Thumbs up w 31
Amazing W car
Alain
Old May 29, 2018 | 07:32 AM
  #35
sschevellecutlass_Bob's Avatar
Love it!! Noticed you have vent in window corner.... my 1970 Cutlass S does not have one......did they make both types of door windows in 1970?
Old May 29, 2018 | 07:39 AM
  #36
Sport Coupes (2dr post) used vent windows through the 1972 model year. Holiday Coupes (2dr HT) stopped using vent windows with the 1969 model year.
gearheads78
Jun 27, 2013 12:33 PM
Nickyloves442s
Oct 24, 2012 04:55 PM
charlierogers
Oct 14, 2011 09:44 AM
