Mystery Steering Column, 1970's floor shift tilt
Old April 8th, 2018, 09:45 PM
2blu442's Avatar
Hi All
I've got a friend who purchased a 1971 Cutlass that had this floor shift tilt column in it. She decided it wasn't right and replaced it with a column that was correct. She's asked me to see if I could sell this for her, but first I need to figure out what it came out of. I've looked at photos on ebay until my vision blurred, but still haven't found one that matches it. I believe the key issue is the little arm and loop for backdrive linkage. The blinker and tilt arm don't match and can be easily changed, so I ignored those. It appears to be the same length or very close to a 1972 Cutlass column. The wiring harness has 7 wires that match, but the three on the lower end are different colors. Here's some photos... anybody recognize this or have a suggestion what it might be out of? John
2blu442 is offline
Old April 8th, 2018, 09:48 PM
2blu442's Avatar
Here's some more pictures.
2blu442 is offline
Old April 9th, 2018, 04:42 AM
Maintained
scottv442's Avatar
looks like a 1976 cutlass tilt column. same as in my pic.
sold this one last winter for 150.00cdn
scottv442 is offline
Old April 9th, 2018, 07:13 AM
The 1973-77 A-body columns are nearly identical to the 69-72 columns. The main difference is the shape of the shifter linkage arm at the base of the column.
joe_padavano is online now
Old April 9th, 2018, 07:49 AM
2blu442's Avatar
Thank you Scott, Joe. The little arm for the linkage has slightly different bends on the column I have compared to Scott's 1976 column. I don't know how hard it would be to change this out, or modify the arm if it doesn't exactly line up on a car. John
2blu442 is offline
Old April 9th, 2018, 08:12 AM
That arm is an integral part of the shift tube, so changing it out involves completely disassembling the column. An easier solution is to modify the rod that runs from this arm to the equalizer rod.
Old April 9th, 2018, 09:32 AM
crimsoncolby's Avatar
I have a tilt floor shift strg column from both a '76 Chevy Laguna and '75 H/O and the linkage arms do not look like the one on your mystery column. Also, the firewall mtg flanges do not have the same shape as yours. Otherwise, they look about the same. Not sure what you've got.
crimsoncolby is offline
Old April 9th, 2018, 11:30 AM
Ancient Iron's Avatar
Is it possibly out of a Chevy p/u or Blazer???? Maybe Jeep they used a lot of G.M. components.
Ancient Iron is offline
Old April 9th, 2018, 10:15 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
That's what I was thinkin. A stick GM truck. Damn close to a colonnade or other mid-70s GM A body though.
droldsmorland is offline
hvysupreme
February 18th, 2017 12:40 PM
David DeCan
January 23rd, 2016 09:10 AM
Rocketbrian
October 2nd, 2013 10:18 AM
442dale
February 7th, 2013 07:03 PM
Bitburger
December 30th, 2012 04:49 PM
Quick Reply: Mystery Steering Column, 1970's floor shift tilt
