Under dash heat/ac parts?
Old March 3rd, 2018, 04:04 PM
Platinum69's Avatar
Can someone tell me what parts I'm missing for under dash ducting? Or does someone have a diagram? It' a 69 442. Thanks
Platinum69 is offline
Old March 3rd, 2018, 05:22 PM
oldspackrat's Avatar
[I]Your car must have been the early build. The parts circled in blue are the first design but at some point they switched to a fabric flexible duct going to the passenger side as well as the driver side. In my experience this plastic L-shaped tube is pretty hard to find. So it looks like you are missing 4,5, 7,8, 14, & 15. I have 14 & 15 if you need them.
I can't tell for sure but it looks like you might be missing the actual movable vents in the top center dash piece & both sides? I probably have those also.
oldspackrat is offline
Old March 4th, 2018, 01:39 PM
Platinum69's Avatar
I have the adjustable vents, just didnt' put them in pic. What condition are the parts you have? Thanks
Old March 5th, 2018, 11:40 AM
This hoes is the only piece I have for you. It is an aftermarket piece but is very flexible and is long enough you could cut it to the proper length for your defroster hoses. Give me a call if you want? 317-727-7041.
Old March 8th, 2018, 07:06 AM
babailey's Avatar
Is there a similar picture of the HVAC duct work for a 1967 CS Holiday Coupe?
babailey is offline
69442murph
June 27th, 2020 07:12 PM
Dream Whip
August 9th, 2016 02:59 PM
Rickman48
March 23rd, 2013 01:06 PM
smcurro
Paint
January 29th, 2012 02:31 PM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: Under dash heat/ac parts?
