Bushing
Old March 5th, 2018, 09:02 AM
Oldpac62's Avatar
Bushing
Does this fit 62 olds starfire? Upper front control arm if is the right one is there something missing from it.?
Oldpac62 is offline
Old March 5th, 2018, 05:36 PM
Phantom Phixer
Charlie Jones's Avatar
Looks like an aftermarket upper arm bushing (Moog ?)
I had a couple of these for my '63 and then I found a set of NOS factory bushings .
I put them back on flea-bay .
Charlie Jones is offline
Old March 5th, 2018, 06:13 PM
Oldpac62's Avatar
Bushings
thank you Charlie, I will see what I can do if there not right.
Oldpac62 is offline
Old March 5th, 2018, 06:46 PM
Oldskeeper's Avatar
The ball joints in the back ground are correct, the upper control arm bushings on a 62 starfire are supposed to be a needle bearing with dust shields and only starfires had them as all the other full size 62's had rubber. These bushings are the moog K5171 urethane bushing and I believe they will fit. They will fit my car and should you decide not to use them I'll take them for my 63. These bushings will stiffen up your ride and take away some of the what I call the rolling couch feel and make it more of a sporty ride. I have these in my 63 98 custom sport coupe and I need another set for my convertible.
Steve
Oldskeeper is online now
Old March 5th, 2018, 07:59 PM
Oldpac62's Avatar
Steve
Steve I need to start putting this back together before the motor comes back thank you for your info you have been a lot of help Mel
Oldpac62 is offline
tim72
Drivetrain/Differentials
April 3rd, 2009 09:00 AM
The Stickman
Chassis/Body/Frame
December 17th, 2008 04:18 PM
maskinen
Chassis/Body/Frame
November 5th, 2008 11:31 AM
crank.it
September 14th, 2007 08:52 PM
miti12
Alero
July 27th, 2007 09:56 PM
Quick Reply: Bushing
