67 Cutlass Holiday Coupe, 1 owner restoration project
I'm several months into a restoration project of my mother's 67 Cutlass. She bought the car new in 67 in Dallas and it is time to bring it back to its former glory- or better. It has spent the majority of its life outside and was not running from 2000 till 2012. I got it running again in 2012, and parked it in a garage until several months ago when it was moved to the garage where the work is being done. The plan is to rebuild the original engine (330) and transmission (2 speed with switch pitch), upgrade the suspension and add front disc brakes. Also plan to add dual exhaust and most likely add 442 badging and a louvered hood (if I can find one!) Also planning to get rid of all the rust and repair the metal, new interior and paint.
1967
November 2017
November 2017- the black paint was added in 2012. It is not an original 442.
1967
November 2017
So a little more history about the car... The car was driven by my mother as her daily driver from 1967 until 1984. It then sat outside at their house in Dallas until 1990 when my father rebuilt/restored it the first time for my brother and I to drive in high school. He rebuilt the engine and did some body work and a new paint job. As we will find out later, it was in a pretty bad hail storm at some point in time. I drove the car from 1994 until 2000 as my daily driver. I got another car at that point and the cutlass was parked at my parents house again outside until 2012. I got it running again in 2012 (and added a HEI distributor) and moved it into a dry storage facility- I started it about once per year until 2017. When I started the engine in November 2017 to drive it to another garage for restoration, it started up easily. 330 V8, 2bbl carb, 2 speed trans with switch pitch, single exhaust
disassembly about to begin, November 2017
some significant rust from leaky batteries on the front left inner fender and core support that needs repair
The engine and trans are now out. The engine is being sent to Speed Specialties Racing Engines in Balch Springs TX for a total rebuild/parts upgrade and likely bore and new custom hydraulic cam. I will include all of the specs and changes made to the engine when it gets back to the shop. Adding a different manifold for 4bbl carb- and we have talked a little about adding fuel injection. Transmission is already back from being rebuilt by the gents at Plano transmission. They said they don't see many switch pitch torque converters anymore and sent that part off to a specialty shop somewhere else in the county for a heavy duty rebuild. I'm not sure where the stall is set- will find that out.
about to scrape off 50 years of grease and dirt
330 V8 original engine
switch pitch torque converter, 2 speed (I think?) automatic transmission, column shift cleaning up the frame. Control arms are being cleaned up and reused. All of the other suspension parts are being replaced.
Disassembly of the front continues. I'm wire brushing the firewall and frame, prepping for paint.
control arms and front suspension about to get removed
cleanup continues
prepping the front of the frame for POR 15
Painted with 2 coats of POR 15. The paint is dry in this picture.
Decoding the cowl tag. There's something odd going on because both the cowl tag and the VIN say that this car is a Deluxe F-85 V-8, NOT a Cutlass. Was that Cutlass badging on the sides and trunk added at a later date? Perhaps when the car was repainted the first time by your father in 1990?
07D = build date, 4th week of July. I assume July 1967, which means it's among the last '67 models built that year.
67 = model year
3 = Oldsmobile
36 = Deluxe F-85 with V-8 engine
17 = Holiday Coupe (two-door hardtop)
LAN = Lansing assembly plant
18656 = Fisher body number
TR 936-A = Turquoise Vinyl (Aqua) Bench Conventional Bench Seat
First Paint K = Aquamarine lower body color
Second Paint K = Aquamarine upper body color
E = tinted windshield and windows
2E = air conditioning
VIN Decode
336177M414556
3 = Oldsmobile
36 = Deluxe F-8 with V-8
17 = hardtop coupe
7 = model year
M = Lansing assembly
414556 = production sequence number at Lansing. The starting sequence number was 100001, so this is a high number, consistent with the late model-year build date.
Only one Cutlass series was produced in 1967, and it carried series designation 38. So if your car were a Cutlass, the first three digits of the VIN would be 338, not 336. The cowl tag number would also be 33817, not 33617.
As I said at the top, both the VIN and the cowl tag say that this car is not a Cutlass. It's a Deluxe F-85 V-8.
The various A-body series' that year, from the 1967 Chassis Service Manual, were
33300 = Standard F-85 with L-6 engine
33400 = Standard F-85 with V-8 engine
33500 = Deluxe F-85 with L-6 engine
33600 = Deluxe F-85 with V-8 engine
33800 = Cutlass F-85 with V-8 engine.
The 00 places were for the body style, in this case 17, which means two-door hardtop (Holiday Coupe).
67 = model year
3 = Oldsmobile
VIN Decode
336177M414556
3 = Oldsmobile
17 = hardtop coupe
7 = model year
Thank you for this information. I guess I was just used to calling it a Cutlass. I found another picture from 67 with the cutlass badging on the left front- same as it is now. Is that not correct? Thanks again with helping me figure this out.
1967
original title
original title
That's cool that you have the original title, but I don't think that's definitive as to the model designation as title office clerks do make errors, and the information they put on the title is only as good as the information supplied to them.
Maybe someone else will have an explanation.
P.S. Your mother was (is?) quite an attractive woman!
I agree with the title possibly being in error. Let's see if we can figure out the answer to the puzzle! Yes she is a pretty lady. She doesn't know about the rebuild and going to hopefully surprise her with it.
I always thought that it went as follows:
http://www.oldsmobility.com/oldsmo/v....php?f=12&t=18
33300 (F-85)
Standard F-85
L-6 Engine
Club Coupe (post)
Station Wagon - Two Seat
Four-door Town Sedan (post)
33400 (F-85)
Standard F-85
V-8 Engine
Club Coupe (post)
Station Wagon - Three Seat Extended
33500 (Cutlass)
Deluxe F-85
L-6 Engine
Hardtop Holiday Coupe
Four-door Hardtop Holiday Sedan
Convertible
33600 (Cutlass)
Deluxe F-85
V-8 Engine
Convertible
33800 (Cutlass Supreme)
Cutlass F-85
V-8 Engine
Sports Coupe (post)
Convertible
Custom Station Wagon - 2 Seat Ext.
33300 (F-85)
Standard F-85
L-6 Engine
Club Coupe (post)
33400 (F-85)
Standard F-85
V-8 Engine
Club Coupe (post)
33500 (Cutlass)
Deluxe F-85
L-6 Engine
Convertible
33600 (Cutlass)
Deluxe F-85
V-8 Engine
Convertible
Cutlass F-85
V-8 Engine
Sports Coupe (post)
Convertible
Core support needed repair which has been done and sent off to powder coating with a bunch of other stuff. We decided to reuse the control arms so I got those cleaned up with a wire brush and angle grinder and prepped and painted with POR 15.
Left side of core support
repaired all of this, including core support off to be powdercoated semi-gloss black
upper control arms before
After POR 15
After POR 15
Front disc brake, rear drum package from Summit with new spindles and Ride Tech Street Grip suspension added with new ball joints, springs, shocks, front and rear sway bar. There was no rear sway bar originally, but there were mounting holes present, so it bolted right on. While we are waiting on the engine to be rebuilt, we started stripping paint and fixing areas of rust.
several rusted out places down low on these panels on both sides
back left panel filled with bondo- will need repair
NICE, back in the DAY I met W.O. Bankston on several occasions in Dallas. If you grew up in the Dallas area, you would also remember R.O. Evans Pontiac-GMC? His son Rusty and I were best friends back then. RO and WO were good friends as well. I worked for Jim Allee Oldsmobile then. He was a great guy. He started out selling Chevy's at Doran Chevrolet in the 60's until he got his own Oldsmobile deal. FYI-I have some new suspension parts and other junk etc. sitting on the shelve collecting dust in the shop form my 64 Pro-Touring build. Let me know if you need anything.
The awesome cassette player is going away. We need to order new dash pad which I think we can get from OPG. The cigarette lighter got stuck on at some point and melted the bezel around it. Does anyone know if someone can refurbish this, or is there a replacement part available?
In case anyone is wondering what tape that is... Van Halen, 1984.
melted!
67 = model year
3 = Oldsmobile
VIN Decode
336177M414556
3 = Oldsmobile
17 = hardtop coupe
7 = model year
67 = model year
3 = Oldsmobile
VIN Decode
336177M414556
3 = Oldsmobile
17 = hardtop coupe
7 = model year
I think the problem is that the service manual was printed early on, and the model designations changed before the cars went into production.
Here's a page from the '67 Dealer Specs Book. It shows the 36 series as being Cutlass and the 38 series as being Cutlass Supreme. The date of printing of the specs book is March 1967, well after the service manual would have been printed if the one I've been looking at was printed in time for the start of the model year.
The car is a Cutlass, not F-85 not a Cutlass Supreme. The early picture shows the Cutlass side chrome and correct rear bumper and reverse light location and trunk lid chrome. Yes a later picture shows a Supreme bumper so it was swapped. This is no biggie. The factory manual as said was printed early with 66 info carried over. The later spec sheet is accurate. Only the Cutlass Supreme got the dual brake light bumper with the reverse lights mover in toward the center.
It's becoming more clear now. Thanks for the info. I found some more old pics and apparently the bumper was switched- most likely during the 1990 remodel. I do remember now that there was a problem with the bumper. The exhaust for some reason was heating up that back right side of the bumper and caused some erosion? I had forgotten about that. I remember we had to be very careful around that back right side because it was so hot. I burned my leg on that old bumper! That must have been why it was switched to a different bumper. I will ask my dad and see if he remembers doing it. The picture in the snow (in Dallas- it never snows like this anymore!) was me in 77 or 78 and it still has the original bumper- and it looks like some rust or erosion developing on the back right. The other pics are from 1990.
1977 or 78. Original bumper. Dallas, TX
1990- I can't tell if this is the original or the switched supreme bumper, but I think it had already been replaced at this point. I remember the small wreck that took out the right front fender- Mom hit something.
bumper has been removed 1990
1990. Sweet paint booth Dad!
1990. Different bumper installed at this point.
All the pieces came back from 3D powder coating of Dallas today (not all are pictured). I think they turned out very well, especially the core support and the inner fenders (these are the originals). New dual exhaust manifolds for the 330 from Supercars Unlimited came back from 3D looking great with the new black ceramic coating. The radiator is now a 4 core (3 regular plus 1 high efficiency- I'm told) and came back to the shop a few weeks ago. The plan now is to start reassembling parts on the fire wall and hopefully the engine will be back in a few weeks. Paint stripping continues.
Thank you for taking the time to share the pictures you have. Yes it should be a 2 speed transmission. But are you sure that the torque converter is a switch pitch? The reason I ask is I've been under the impression the switch pitch torque converters had extra weld dots on them. The photos below, the one on the left has the dots I'm describing. John
Weld dots
No dots
Weld dots
No dots
AWESOME! Fantastic work ethic, and lotsa patience, seems to me. Can't wait to see the finished product. Anyone old enough on CO to remember Triangle Olds down on Cedar Springs (I think). My uncle Bodie was a salesman there, and I bought my '50 88 2 door post (used) from him in 1956 for $500.00. Oh, my goodness, sure wish I still had it!!!!
I honestly didn't know much about the switch pitch trans until we got it to the trans shop. The guys there told us all about them when they saw this transmission. I know that the transmission itself has the switch pitch feature and there is the mechanism on the fire wall that links it to the accelerator. Is it possible that the torque converter was changed to a non switch pitch the last time it was rebuilt (only 1 time)? Will that even work with this trans?
No dots
No dots
Progress continues. Paint is now all off and down to bare metal. Rust areas in lower panels, trunk and front driver and passenger floors are being repaired. There are also several rusted out areas around the windshield. We are hoping that the rust around the back window isn't too bad, will find out soon.
rust holes to be filled on both sides of the trunk
back left
rust being cut out of the trunk and replaced
back left
some rust holes at the front of the hood that will be cut out.
several rust holes on driver and passenger side that will be cut out
patch panel finished on the left side of the trunk
patch panel going into the trunk. I wonder how all this water got back here?? passenger side rust
driver side rust
driver side rust
Looks good, I don't know if you have seen another members thread about repairing a 67 Cutlass rear window? He did a great job, you may want to look at it for pointers. His name was 67supreeeme.
Progress slowed down a little this summer, but hopefully will pick up this fall. The engine is still at the rebuild shop, but should be finished soon. In the meantime, work continues on reinstalling the a/c and repairing the duct-work under the dash. The 10 bolt rear end is out for cleaning and repainting and adding different gears (3.7) and a posi.
