What have you done to your Oldsmobile today
Old December 21st, 2017, 09:39 PM
  #1641
GEARMAN69's Avatar
LED dome light bulb !
GEARMAN69 is offline
Old December 24th, 2017, 01:29 PM
  #1642
Cincinnati Rick's Avatar
Suspension Work and Paint
Installed new bushings, springs, shocks and ball joints.
I think my buddy John was thirsty after sand blasting.
Moog parts
Upper control arm mounting hole is looking a little egg-like
Thanks John for the free replacement!
Painted and ready for installation
Faux W27 rear end paint. Asked for a W27 cover for Christmas so I hope it's under the tree tomorrow morning.
Cincinnati Rick is offline
Old December 24th, 2017, 01:53 PM
  #1643
Gary M's Avatar
Looks great
Faux-W27 color? Nice!
Gary M is offline
Old December 25th, 2017, 06:07 AM
  #1644
dennis_30281's Avatar
Control arms
Looks nice Charlie, I've been busy modifing the upper control arms off of the donor car. I'm moving the ball joint hole back 11/16" and hope to get 4 degrees of positive caster.
Dennis
dennis_30281 is offline
Old December 27th, 2017, 05:21 PM
  #1645
Tymiles24's Avatar
66 cutlass convertible
Started my engine rebuild by removel of the 330...
Tymiles24 is offline
Old December 27th, 2017, 05:23 PM
  #1646
Tymiles24's Avatar
Also ordered all my stereo equipment from custom autosound today too
Old December 28th, 2017, 05:59 PM
  #1647
Phantom Phixer
Charlie Jones's Avatar
Dennis
Why ?
Charlie Jones is online now
Old December 29th, 2017, 01:16 PM
  #1648
Travlr's Avatar
Added 6 inches to the length of the frame/wheelbase in the donor car (95 Caprice) to put under my 1950 Olds 98. Easier than I thought it would be. I didn't have to cut and splice any fuel or brake lines and they all went back into the original clamps so they'll be out of the way.
Travlr is offline
Old December 30th, 2017, 09:52 AM
  #1649
GEARMAN69's Avatar
All new LL 1157 bulbs in back of wagon after a few headlights replaced and found a wire I had connected that made the blinkers crazy and cut that. It was trailer harness. Now it works perfect. Oh and then scored a new in box Olds cam for $75 and a almost complete 67-68 TO code 31 spline 3.91 rearend on the cheap cheap cheap
Old December 30th, 2017, 03:26 PM
  #1650
Tymiles24's Avatar
Slowly getting there..
Old December 30th, 2017, 08:11 PM
  #1651
Polarbear007's Avatar
New shoes...cooper cobra gt's
Polarbear007 is offline
Old December 31st, 2017, 09:51 AM
  #1652
Thanks Gary......This is the paint that was used.
Old January 2nd, 2018, 06:02 PM
  #1653
Travlr's Avatar
Put the first floorboard in of four. Left rear Went easier than I expected.
Travlr is offline
Old January 2nd, 2018, 07:17 PM
  #1654
Phantom Phixer
Jack and I put "Suzy's " rear end back in. (Jack not name , Jack job !)
Jack gently lifted her rear into place while I wiggled it around and slid in all the bolts.
Old January 5th, 2018, 05:02 AM
  #1655
one buddy's Avatar
air cleaner assembly
finished restoring orig air cleaner assembly
one buddy is offline
Old January 5th, 2018, 05:14 AM
  #1656
Nice work!
Old January 5th, 2018, 06:05 AM
  #1657
442fanatic's Avatar
Looks great!
Not much happening here in the frozen Iowa plains, where the high temps have been like 5 degrees, not factoring for wind chill..
Prior, put a new alternator on. Going to look at relocating the engine ground straps, as either the old regulator in the alternator was going bad,or have some bad grounds as the lights flicker when I use the headlights at night.
Going to install a fuel check valve off of fuel tank that I acquired, see if that helps solve the fuel drain back from carb...
Been considering getting some LED 1157 bulbs for the tail lights, on a previous thread several options given, pros/cons, a good video comparing Plasma LED, LED tower, to incandescent.
Off and on working on car's history with family for a binder along with dealer promotional items for car shows..
About all I got
442fanatic is offline
Old January 6th, 2018, 11:12 AM
  #1658
Tedd Thompson's Avatar
Took the Old Lady (Mistress) to the coffee and cars show this morning. The ricers and BMW's were there in mass but the Oldsmobile still stood out despite her age. Good time was had by all..... Tedd
Tedd Thompson is offline
Old January 12th, 2018, 05:44 AM
  #1659
7olds1's Avatar
Had a few hours in shop, waxed and dropped the top, not too bad for sitting close to 30 years. Also added the front marker light trims both sides, been in the box for over 35 years.....😬
7olds1 is offline
Old January 13th, 2018, 06:27 PM
  #1660
Tymiles24's Avatar
330 rebuild
Almost out
Old January 15th, 2018, 08:42 AM
  #1661
RonFX's Avatar
Put in all new firewall and underdash insulation while the whole interior was apart and the dash was out being replated and detailed. Still got a long way to go on the total restoration started a few years ago on the 66 Cutlass I've had since 1975.
RonFX is offline
Old January 15th, 2018, 09:27 AM
  #1662
Big Daddy Spo's Avatar
After Break in run of the new 350. Installed R&M billet wire looms ( painted 350 gold) installed custom length plug wires and finalized HEI wiring. Finished off the day bending up 1/4" tube for TH350 modulator vacuum and secured to manifold.
Big Daddy Spo is offline
Old January 15th, 2018, 12:20 PM
  #1663
GEARMAN69's Avatar
Finally installed a #671 unit in place of the mini spool locked diff on the original 3.08 gears in the red wagon ! Hallelujah !!!
Old January 18th, 2018, 08:28 AM
  #1664
GEARMAN69's Avatar
Drove to work in the dark cold at 5am and 17 degrees with no heater and jumped a big dead hog with right front tire of wagon.. oops No damage as I can tell
Old January 18th, 2018, 08:44 AM
  #1665
With the snow and ice, I put a rear end in my recliner
Jamesbo is online now
Old January 18th, 2018, 04:14 PM
  #1666
Nice!
Old January 18th, 2018, 06:35 PM
  #1667
Nice rearend, here in Stockbridge, Ga where it's been under freezing for 2 days now and snowy I took my rearend apat.
Dennis
Old January 20th, 2018, 07:09 AM
  #1668
Gary M's Avatar
Put my rear end on the floor
Removed the rear suspension and exhaust system. Tank looks new but painted, it's coming out next for the sniper EFI tank after I strip and paint the undercarriage.
Gary M is offline
Old January 24th, 2018, 12:53 PM
  #1669
GEARMAN69's Avatar
Drove wagon last Friday to the little mountains in SE Oklahoma to go meet friends and camp out. No issues at all driving about 600 miles other than bad MPG (12). That carb has always ran and drove well but it never had gotten good mileage. Time to get back in it. I used it on my sons 350 truck and it did the same 12. On his truck I swapped my "race" 800 Qjet on and it got 14-15 ..LOL
Old January 27th, 2018, 01:32 PM
  #1670
rpinnt's Avatar
Tore apart 350 that had been in the car when I bought it. Previous owner said it stopped running "suddenly."
rpinnt is offline
Old January 27th, 2018, 02:02 PM
  #1671
TripDeuces's Avatar
Considering the carnage it looks like you got off easy.
TripDeuces is offline
Old January 28th, 2018, 05:12 AM
  #1672
bw1339's Avatar
"Suddenly" was probably very accurate
bw1339 is offline
Old January 28th, 2018, 05:08 PM
  #1673
Mike77's Avatar
I check in on my girl having her winter hibernation across town. Still sleeping soundly. I better get the Vette fixed soon and out of her spot in the shop. Spring is not to far away.
Mike
Mike77 is offline
Old January 31st, 2018, 02:19 PM
  #1674
Gary M's Avatar
More cleaning
Got some surface rust. Glad I took the tank out.
Got most of the flaking undercoat off. Called it a day.
Gary M is offline
Old February 1st, 2018, 04:08 PM
  #1675
RonFX's Avatar
I got the wiring for the backup lights and console lights figured out for the floor shift conversion in my 66 Cutlass.
RonFX is offline
Old February 1st, 2018, 04:58 PM
  #1676
35tac's Avatar
Ron, sent you PM.
Wayne
Medina,Ohio
35tac is offline
Old March 4th, 2018, 04:49 PM
  #1677
Gary M's Avatar
Coated inside the frame.
Ran an airline thru the frame, washed out a lot of crap with a water hose, let it dry, air line one more time then used Eastwood internal frame coating to seal inside.
Gary M is offline
Old March 4th, 2018, 07:38 PM
  #1678
gbledsoe3's Avatar
Finishing up “custom” radiator hoses. I didn’t ike the way the lower hose fit and rubbed against the idler arm bracket on the frame. Trying to get all the lose ends done before the first engine fire up on March 17th.
gbledsoe3 is offline
Old March 5th, 2018, 12:27 PM
  #1679
Local Hero's Avatar
Road Trip
The roads were mostly dry so I took a 400 mile round trip in the D88 Coupe to Detroit for the Detroit Auto-Rama and rolled the odometer over on the way home. Then had to give it a wash today due to a little bit of road spray. Back into winter storage for about another month or do.
Local Hero is offline
Old March 5th, 2018, 02:46 PM
  #1680
61Bat's Avatar
Finished my steering wheel restoration. 😁
https://classicoldsmobile.com/forums/interior-upholstery/123415-1961-steering-wheel-redo.html
61Bat is offline
Quick Reply: What have you done to your Oldsmobile today
