'50 Olds, disc mod orig style wheels
I'm looking for 15 inch 5X5 wheels that will fit over my calipers and want to use the original caps and beauty rings. Any ideas? Or am I whistling in the wind?
The original wheel has three clips inserted into rectangular holes to hold the cap on.
Thanks Travlr. The plane is a B-24 that is part of the Commemorative Air Force (CAF). It is one of two remaining that are in flying condition. It was at a car show back in 2014 and was a pretty good photo op.
You might try mid seventies chevy five hole pickup wheels they should fit over your calipers and may or may not hold your poverty caps I've never tried to do that but they came with that style cap originally ... Tedd
"Poverty caps"??? LOL, I've never heard that term used. I guess that fits though, as the big wheel covers were probably an upgrade and added $. Thanks for the info and idea on where to find wheels. I'll check out what's available locally and see if I can find some.
Poverty caps is a term that came along much later. In the day those on your car were referred to as hubcaps and the full ones were referred to as wheel covers. You also have the trim rings which were popular.
I'll have to take some pics and post them. I know some of the early 50s Studebakers used a similar set up. I suspect the clips were not used to retain caps past the early fifties.
Hey Charlie:
Here is the thread where he tell about the car. Looks like it will be pretty cool.
https://classicoldsmobile.com/forums...one-again.html
steve walker
June 21st, 2014 06:17 AM
rcdynamic88
September 22nd, 2010 11:13 PM
