8.5" axle code
8.5" axle code
Here is a better picture of my axle code. This is on my 1977 Cutlass Supreme with 350/350. Love to find out exactly what gear ratio I have and what the spline is. IS this a series 2 carrier? Can someone run these numbers for me? Looks like they are:
7 AA 0 003
7 AA 0 003
Axle Codes
For 1977 open differentials
AA 2.41
AB 2.56
AC 2.73
AF 3.08
Convert you differential to 3.23 gears and add limited slip. Best money you will spend today. 3.23 gears are the perfect compromise between performance and drivability with a 3 speed automatic transmission.
AA 2.41
AB 2.56
AC 2.73
AF 3.08
Dave thank you so much for clarifying the AA. I have been hoping for that validation. I have plans for a 200-r4 early next year and with that I have opted to purchase a series 3 carrier with 3.42 gears for now. I have a larger tire ( 255/70/r15 ) 29" tall. So from my research I should be just fine with 3.42 until next spring. even on highways.
Gear choice
I agree - I was thinking about this just this morning.
0.67 overdrive and 3.90 rear gears = 2.61, so similar to what your car currently has and great for highway driving.
On the other end, coming off the line in first gear wold be similar to having 4.30 rear gears with your TH350.
If you're keeping the 28 spline axles, there's a guy on eBay with a brand new Detroit Locker for $470 or best offer. Those things are $650 from Summit. Things to consider instead of getting a no name unit.
Wait,,,,just noticed who's selling it. Another member on here "MONZAZ". He does nothing but rear axles. You should realy consider talking to him. Send him a private message on here, he's great about responding. He'll may cut you a deal on here considering no eBay fees.
https://www.ebay.com/itm/10-BOLT-8-5...19.m1438.l2649
LOWEST price deals
Here is the posi package I was thinking about going with...
https://www.amazon.com/gp/product/B0...A2FG7JTLH1603B
Probably USA standard gear too what ever they want to stick in a box deal
We deal with Randy's ring and pinion and the Yukon gears are better than the USA standard stuff..Which Like I said they will stick richmond excel gears or any cheap gear they find for quantity price. They are not bad as far as strength goes but noise factors could make you crazy...
We have been using Nitro gear...Who ever is doing their gears is very good. They are compatible yukon priced gears...
Jim
J D Race
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
