8.5" axle code
Old Nov 14, 2017 | 12:05 PM
GoolzCutlass's Avatar
8.5" axle code
Here is a better picture of my axle code. This is on my 1977 Cutlass Supreme with 350/350. Love to find out exactly what gear ratio I have and what the spline is. IS this a series 2 carrier? Can someone run these numbers for me? Looks like they are:
7 AA 0 003
Old Nov 14, 2017 | 02:03 PM
I don't know how to decode those numbers, but a 77 Supreme likely has 2.41 gears.
Old Nov 14, 2017 | 05:53 PM
oldsmobiledave's Avatar
Axle Codes
For 1977 open differentials
AA 2.41
AB 2.56
AC 2.73
AF 3.08
Convert you differential to 3.23 gears and add limited slip. Best money you will spend today. 3.23 gears are the perfect compromise between performance and drivability with a 3 speed automatic transmission.
Old Nov 14, 2017 | 07:05 PM
Dave thank you so much for clarifying the AA. I have been hoping for that validation. I have plans for a 200-r4 early next year and with that I have opted to purchase a series 3 carrier with 3.42 gears for now. I have a larger tire ( 255/70/r15 ) 29" tall. So from my research I should be just fine with 3.42 until next spring. even on highways.
Old Nov 14, 2017 | 08:18 PM
Gear choice
With the OD trans you want more gear. Use 3.90 or 3.73s or the recently and newly available 3.55 gears.
Old Nov 14, 2017 | 09:02 PM
I agree - I was thinking about this just this morning.
0.67 overdrive and 3.90 rear gears = 2.61, so similar to what your car currently has and great for highway driving.
On the other end, coming off the line in first gear wold be similar to having 4.30 rear gears with your TH350.
Old Nov 14, 2017 | 09:05 PM
I found a 8.5" posi package with 3.55 gears. Pretty sure I am getting this. Still should be fine to drive for a while in winter with the th350.
Old Nov 14, 2017 | 09:15 PM
Shouldn't be an issue. I drove with 3.23 gears and short 245-60-14 tires for decades. Engine turned about 3200 RPM at 70-ish MPH.
Old Nov 16, 2017 | 06:07 AM
brownbomber77's Avatar
If you're keeping the 28 spline axles, there's a guy on eBay with a brand new Detroit Locker for $470 or best offer. Those things are $650 from Summit. Things to consider instead of getting a no name unit.
Old Nov 16, 2017 | 07:43 AM
Bomber can you give me the link to the Locker on ebay? thanks
Old Nov 16, 2017 | 07:44 AM
Here is the posi package I was thinking about going with...
Amazon Amazon
Old Nov 16, 2017 | 12:53 PM
Wait,,,,just noticed who's selling it. Another member on here "MONZAZ". He does nothing but rear axles. You should realy consider talking to him. Send him a private message on here, he's great about responding. He'll may cut you a deal on here considering no eBay fees.
https://www.ebay.com/itm/10-BOLT-8-5...19.m1438.l2649
Old Nov 17, 2017 | 02:59 PM
monzaz's Avatar
LOWEST price deals
https://www.amazon.com/gp/product/B0...A2FG7JTLH1603B
Yah and get no tech support...
Probably USA standard gear too what ever they want to stick in a box deal
We deal with Randy's ring and pinion and the Yukon gears are better than the USA standard stuff..Which Like I said they will stick richmond excel gears or any cheap gear they find for quantity price. They are not bad as far as strength goes but noise factors could make you crazy...
We have been using Nitro gear...Who ever is doing their gears is very good. They are compatible yukon priced gears...
Jim
J D Race
war eagle
Sep 12, 2015 04:28 PM
Dave Siltman
Sep 28, 2012 12:02 PM
Dave Siltman
Jun 8, 2012 02:49 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
