Click Here
SSII wheel hoops
Old June 21st, 2017, 11:02 AM
Mark30's Avatar
SSII wheel hoops
I am looking to pick up some 15" wheel hoops that would work for the Oldsmobile center diameter. I have a set of 14x6 bolt on cap centers cut out on a lathe and would like to convert them to 15. The only hoops I can find are for the larger Chevy Corvette style centers.
Mark30 is offline
Old June 21st, 2017, 12:10 PM
jensenracing77's Avatar
Can you just get a set of 15x7 snap on wheels and cut the centers out of them and use that rim? 15x7 snap on wheels seam to be common and low priced still.
jensenracing77 is offline
Old June 21st, 2017, 12:13 PM
Funkwagon455's Avatar
Check with McWheels Iowa and Stockton Wheel in CA if they would be willing to sell the blanks alone.
Funkwagon455 is online now
Old June 21st, 2017, 12:42 PM
Mark30's Avatar
I have a set of 15x7 snap wheels but I want the bolt on centers. I see what you are saying but I don't want to pull apart the snap center wheels. Not a bad idea though.
Funkwagon, I see mcwheels has the chrome hoops. I did send a message but haven't heard back. I am also looking at building some 15" nova 6 hole rally which have the same hoop and center as the oldsmobile rally.
Mark30 is offline
Old June 23rd, 2017, 07:43 PM
Don't forget to check with Stockton as well
Old June 24th, 2017, 10:10 AM
4speed455's Avatar
The nova wheels May looks similar to the olds but they are different.
Oldsmobile SSIII
Nova 6 hole rally
4speed455 is online now
Old June 24th, 2017, 11:30 AM
I think the point was that the Nova wheels use the same diameter center disk (not the same disk, just the same diameter) and thus the hoops are the same.
Old June 24th, 2017, 01:36 PM
This thead got me thinking about a source for the SSII/III hoops (bands) again. As have others, I've been searching on and off for a while now. I just happened to stumble over a website for a company called Race Engineering, in Australia. They list wheel bands in 15x8 and 15x10 sizes with a 312mm inside diameter. For the metrically challenged, that is just about 12.25", which is exactly the size of the SSII/III wheel center disk. (Note that the wheel bands that Speedway Motors sells have a 12.625" I.D.) The photo of drop center wheel bands on their website looks promising. I've fired off an email; we'll see what comes of it next week. At this point, I don't even know if they will ship to the U.S. Any interest in a lot buy if I can work a deal on these?
http://www.raceengineering.com.au/wheels.htm
Old June 24th, 2017, 02:38 PM
Mark30's Avatar
I'm interested in hearing what they have and if they ship.
Mark30 is offline
Old June 24th, 2017, 02:41 PM
Mark30's Avatar
When I first started looking. I thought it would be easier to find them as I believe that the Cragar SS wheels used the same size hoop. The 14 and 15 inch wheels shared the same center disk.
Mark30 is offline
Old June 25th, 2017, 07:38 AM
When I sourced the last three ten inch hoops from Jimmy at Rally America, he told me that if I needed more they could probably be sourced from Carlisle Wheel in Ontario California. I'm sure that if they do have them, they would be available in 7"-8" flavors as well. He also had mentioned that they likely only come by the pallet load. This could potentially be a less expensive option for those of us in the USA or Canada..
Old June 25th, 2017, 08:34 AM
Mark30's Avatar
I feel silly asking, but how many would be on a pallet load?
Mark30 is offline
Old June 25th, 2017, 12:29 PM
I don't think that's silly at all! I have no idea either. Just have to call them and ask.
Old June 25th, 2017, 06:41 PM
Yellowstatue's Avatar
Think about two dozen or so on a skid. Seems to me that there is a company in T.O. that makes hoops as well. West side, near the Queensway, maybe Atomic Ave.
Yellowstatue is offline
Old June 25th, 2017, 08:24 PM
steverw's Avatar
Does anyone know if this is the same center size of the SS1's?
steverw is offline
Old June 26th, 2017, 08:24 AM
stevengerard's Avatar
Why not look for a set of 73/74 15x7 bolt on center cap rims in the first place . maybe cheaper in the long run.
stevengerard is offline
Old June 26th, 2017, 08:27 AM
It will be cheaper if 7" wide rims are what you want. Obviously a source is needed for 8" and wider hoops.
Old June 28th, 2017, 01:21 PM
Mark30's Avatar
I think the SS1 wheels are the same but measuring would be a good idea. I want to say all 14" gm wheels have the same diameter but I may be wrong. I wonder if the 14" chevy rally wheel has the same inner diameter.
Mark30 is offline
Old June 29th, 2017, 04:34 AM
Mark30's Avatar
I have found that Carlisle wheel produces the wheel hoops. Apparently the same hoops are used when making 15" Mopar steelies
Mark30 is offline
Old June 29th, 2017, 07:42 AM
Do you have a point of contact? Will they sell them retail?
In Googling Carlisle Wheel, I found that their parent company (the Carlstar Group) also owns Cragar.
By the way, I heard back from the company in Australia. They said they buy their hoops from a source on the east coast of the US, but did not provide a name. Still searching.
Old June 29th, 2017, 08:15 AM
Mark30's Avatar
The information was found on a mopar forum. One guy was purchasing them from Carlisle in pallets. I have emailed that guy and will see what I can come up with.
Here is the link to the forum
http://board.moparts.org/ubbthreads/...el-wheels.html
Mark30 is offline
Old June 29th, 2017, 10:15 AM
And here is the potential problem:
I usually buy 15 - 25 pallets worth of outers and a few of centers at a time....
From the photos, it appears that a pallet worth has 45 hoops.
Old June 29th, 2017, 10:17 AM
Mark30's Avatar
Yeah, it looked like a big problem. I am not interested in entering the wheel manufacturing business
Just keep searching.
Mark30 is offline
Old July 10th, 2017, 03:22 PM
McWheels
mcwheels's Avatar
Call me on wheel hoops and leave a message I only look at this forum about once a month. 515-450-3446, Curt at McWheels
mcwheels is offline
Old June 27th, 2018, 11:48 AM
Mark30's Avatar
Reviving the thread for today. Has anyone had any luck finding these wheel hoops?
Mark30 is offline
Old June 27th, 2018, 01:32 PM
McWheels
mcwheels's Avatar
Chrome wheel hoops
Call or text I finally have some 10" chrome wheel hoops, 515-450-3446. Curt
mcwheels is offline
timothypaul
September 5th, 2013 07:37 PM
Greg Rogers
Wheels and Tires
January 1st, 2013 05:37 PM
1971 442 convert
Wheels and Tires
16
January 18th, 2012 01:00 PM
esisson
January 22nd, 2011 04:21 AM
RPD1659
October 20th, 2008 12:26 PM
Quick Reply: SSII wheel hoops
