Moser Rear End For 1967 Delmont 88?
Moser Engineering makes a 12 bolt rear end assembly for 1965 through 1970 Impalas (B-body) that you can configure with a 5 lug 5 inch bolt pattern and get pretty much any gears you want.
Will a big Chevy rear from those years bolt into a '67 full-sized Olds?
The 1965-70 Impala chassis and suspension is COMPLETELY DIFFERENT from that on the 65-70 Olds full size. NOTHING interchanges.
The Impala uses a THREE link rear suspension with a panhard rod. The Olds uses an angled FOUR link.
The Chevrolet body 1958 ? 1959/1964 had the panhard bar and carrier bearing drive shaft. Pretty sure 1965 thru 1970 was 4 link. No its not bolt but my Nephew had a Impala 12 in a 1967 Delta. You'll need to do some fabricating. Jmo
![](https://cimg0.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/750x562/med_1367340889_dscf0401_dd61cd5651d6102aeccaf5e9c7fd53feffe58d55.jpg)
monzaz
July 6th, 2017 06:59 AM
1967 Delmont 88
July 12th, 2010 12:26 PM
