68-72 Interior Lower Air Deflector Duct
Old April 14th, 2017, 05:35 AM
Cincinnati Rick's Avatar
70-72 Interior Lower Air Deflector Duct
In need of a 70-72 interior, lower air deflector duct for a console car. I know they sell reproductions but wanted to check to see if anyone had one they could part with.
Cincinnati Rick is offline
Old April 14th, 2017, 06:14 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
ros68-72 in the classified section here should have it. 68-69 is different from 70-72
droldsmorland is offline
Old April 14th, 2017, 06:22 AM
Thanks for the heads up. Figures OPGI description would be wrong. I'll hit ros68 up and see if he has one.
Old April 17th, 2017, 05:38 PM
Someone has to have one of these stashed away right?
Old April 18th, 2017, 06:17 AM
Rick ros6872 didn't have one? Find that hard to believe. Try olds442edbaret (Tom) he parts cars as well.
https://classicoldsmobile.com/forums...ash-parts.html
https://classicoldsmobile.com/forums...***-parts.html
Old April 18th, 2017, 06:21 AM
He did not.
I'll check with Tom
Old April 18th, 2017, 06:31 AM
Also place an add in the parts wanted. Tom hooked me up with several under dash plastic pieces. Hes great to deal with and the parts are as described.
Old April 18th, 2017, 06:42 AM
Have you had your coffee this morning? This is the "parts wanted" section.
Old April 18th, 2017, 07:01 AM
Duh...I answer so many threads that it all blends together in my personal inbox as it just sends the link. And yes my brain is not in gear this AM :^).
I thought these were being reproduced? Have you googled it yet? Call OPG and speak to a person. I am positive I saw all of the under dash pieces in an exploded view on one of the resto houses sites. But that doesn't mean they are being reproduced.
Old April 18th, 2017, 07:10 AM
OPGI does have them but I only wanted to see if I could find an OEM type first.
Old April 18th, 2017, 07:14 AM
Agreed, older is better...and it's USA plastic! That's why I bought used too. I needed that piece above the brake pedal. But wound up buying most of what Tom had just because it was available. Good luck. Hopefully, Tom has one. He has all of his inventory cataloged and boxed. Very organized.
Old April 28th, 2017, 10:18 AM
Cory
dream66's Avatar
Looks like I'm in the same predicament - sorta.
I'm not sure what I need without a diagram of the ductwork for 72 with console. All I know is that there is no air flowing out of the upper left and below dash vents.
dream66 is offline
Old April 28th, 2017, 02:15 PM
oldspackrat's Avatar
dream,
I can probably hook you up with the missing pieces. Give me a call?
Scott
317-727-7041
oldspackrat is offline
Old April 28th, 2017, 02:23 PM
Cory
dream66's Avatar
Thanks Scott, I'll get a pic of what's there and post it first
dream66 is offline
Old April 29th, 2017, 09:36 PM
Cory
dream66's Avatar
Scott,
Here's an under dash pic of the driver side looking inward and the passenger side looking inward.
No ducts are attached to the under dash vents and no duct to the upper driver side vent.
dream66 is offline
KZ442
May 4th, 2014 08:03 PM
DrOlds69
October 18th, 2013 04:29 AM
Bernhard
April 27th, 2013 10:54 PM
Nufo
March 25th, 2012 05:56 PM
BonnersFerry442
Chassis/Body/Frame
May 24th, 2010 09:25 AM
Quick Reply: 68-72 Interior Lower Air Deflector Duct
