1984 Delta 88 Oil pressure gauge pinned (307 V8)
Old Apr 4, 2017 | 11:34 AM
Certified Idiot's Avatar
Last summer, my oil pressure gauge was acting up. The second I fire up the engine, the gauge buries itself past 400 kpa. Then after I drive it around and it warms up, I'll stop at a light and the gauge starts bouncing all over the place until I drive off. Every once in a while while I'm stopped, it'll actually work properly and it reads just under 200kpa, but that only lasts for a few seconds before it either pins again or goes back to jumping around.
My guess is that the oil pressure sending unit is at fault here (which I don't know where it is), or maybe there's a bad connection or exposed wire somewhere. But either way, I'd like to get as many pointers as I can so I can get a running start at diagnosing and fixing it when I get it out of storage in a few weeks.
Old Apr 4, 2017 | 09:06 PM
Stock gauge or aftermarket? Electric or mechanical gauge?
ASSUMING it is a factory gauge, disconnect the wire at the sender. With the key in the RUN position, the gauge should read zero. Ground the wire to the sender. The gauge should read full scale. If this works, the problem is the sender. If this doesn't work, the problem is the gauge or wiring to it.
Old Apr 5, 2017 | 01:27 AM
don71's Avatar
same but different
In this picture, its right in the center. Note, yours might look a little different.
70 ctls
Feb 9, 2015 04:50 AM
dacutty
Mar 28, 2014 09:01 AM
foreverolds
Dec 1, 2012 07:07 PM
tecar442
Jun 14, 2009 06:08 PM
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
