455 piston ring thickness
Old December 13th, 2013, 07:43 AM
joepenoso's Avatar
1.)I see they have two thicknesses of rings for 455 pistons .....one is 5/64, 5/64, 3/16
2.) And the other is the more "Modern" 1/16, 1/16, and 3/16 inches/
What benefits and disadvantages concerning the two sizes assuming both pistons are forged and have same compression heights
thanks
joepenoso
joepenoso is offline
Old December 13th, 2013, 07:58 PM
joepenoso's Avatar
Ttt
Old December 14th, 2013, 06:57 AM
cutlassefi's Avatar
Same answer as what's posted on ROP. You asked the same question there.
cutlassefi is offline
Old December 17th, 2013, 06:13 AM
507OLDS's Avatar
Your modern pistons will generally have thinner rings. Look at today's engines,like the LS engine,that run well over 100,000 miles,and how thin their rings are.
507OLDS is offline
Old December 17th, 2013, 05:00 PM
cutlassefi's Avatar
Correct but that's only part of it.
You have good cylinder wall strength/integrity, better materials and cleaner running engines that don't have an issue with fuel laden oil, as most EFI'd engines today only run in cold start mode for less than a minute.
W-27
September 23rd, 2014 10:16 AM
OLDSmobility
May 13th, 2011 07:05 AM
mlouderback
March 29th, 2011 11:56 AM
RAMBOW
January 25th, 2011 11:12 PM
peaconn
May 15th, 2008 06:32 PM
Quick Reply: 455 piston ring thickness
