Dual Port Manifold
Old Oct 11, 2025 | 02:42 AM
JerryW's Avatar
Dual Port Manifold
For the most part the only intake that we won't have tested on the dyno, by the time we get done (if that every happens) is an Offenhauser dual port. Initially I had no desire to test one as it will make less HP than a conventional intake, the divider between the two ports will be a restriction and it won't make as much power at higher RPM due to this divider being a restriction. I still 100% believe this. However, I think if this intake is ran with a vacuum secondary carb, and the right spring, it MAY make more low end torque due to the higher velocity of the smaller port. Now, this higher velocity air will hit the head and it may slow down enough to not have any impact. But I'd like to try.
In 2024 I seen quite a few of these at Homecoming and Nationals. However this year I didn't see a single one. Does anyone have one we can borrow, or purchase (but not that much money)? The engineer in me wants to try this. I won't lose sleep if we don't, but it may actually yield more torque.
jerry
Old Oct 11, 2025 | 05:11 AM
cutlassefi's Avatar
I’d like to see this as well, but I believe it will make less horsepower AND torque. I’ll keep my reasons to myself for now, but it would be great to have tasted every intake ever offered for the big block Olds.
Old Oct 11, 2025 | 06:57 AM
2blu442's Avatar
I've got one your welcome to borrow or buy, cheap! Send me a PM and we can work something out. John
tiogatwister
Nov 25, 2021 08:55 AM
bob provost
Mar 1, 2018 11:26 AM
1968ragtop
Jun 14, 2013 09:04 AM
70olds455
Aug 26, 2012 09:29 PM
silverriff
Jul 12, 2008 08:43 AM
