Comp Roller Lifters
the reason I asked is because it’s hard to believe that many just failed all at once.
Could have been valve float or something. Link bar hitting the valley tray, if he had one, is a problem on Pontiac’s.
I would check the broken link bars for damage inside the slot ends and the upper edges
check one of the ones that aren’t broke through a full rotation while checking the link bar for clearance
My link bar is .085" on my digital caliper for thickness. The valley tray makes sense. Hitting that a high rpm would be very bad. I like the Turkey Tray gasket but with a roller cam, aluminum heads with BBO ports it is not worth all the modifications necessary to run one on a SBO.
They're probably going to warranty them, but we don't know to what extent. Sure, they'll have no problem sending out another box of lifters, but what about the Butler cam (Comp core) and other rebuild expenses? Also, would you put them back in after failing so quickly?
What likely went first, the roller or the link bars?
Btw- the ones your friend has weren’t actually made by Comp. They are now, they own the factory.
I called them today. The evolution series just changes the guts to a cartridge. The link bars, body, and roller are the same.
The Morel/Ersons sure look beefier in comparison. Why did you quit selling them, again?
Actually Comp is using their mech roller bodies for most of the new Evolution series lifters. That means the wheel size goes from a .700 to a .750 on the Olds/Pontiac stuff, not a bad thing. And not sure how many failures they had on the solids in the past, but they felt that was the best route moving forward for the new lifter.
I don’t use a lot of the comp hyd roller lifters , but the ones I have used are still running fine. 6k plus with no pump up. They do need more seat pressure and near zero lash..1/8 to 1/4 max
Ive used Howard’s hyd rollers and no issues with them. I don’t know who makes theirs
I know this is a few days old but I want to add that lifters dont fail like that unless there was something in a bind or maybe over revved. It might be the picture but it looks like the pushrods on the left side in the picture have been very hot ? Especially down near the lifters ? Somethings not right. I have used a ton of Comps lifters and have never had one fail. I have them in several marine engines that are 5 years old or more and they take a beating.
They need to put some checking springs on the heads and run the thing through a few revolutions and see what it is doing.
it’s real easy to spot. Gatermans look like the old Crane stuff, they’re here in Fl and I think they bought some of the machinery.
Johnson’s have a look all their own as well.
Morel does private label for Howard’s, Lunati, Erson, and some of the warehouses so those all look the same. But their quality has gone down. And according to John Callies at Morel, they won’t stand a lot spring pressure either.
Either noisy (like a sewing machine) or wouldn’t bleed down and would hold the valves open once you fired the engine.
