434 Stroker build
Old Apr 22, 2021 | 02:34 PM
cutlassefi's Avatar
434 Stroker build
Finished a 434 Stroker a couple of weeks ago;
4.155” bore Mahle piston 10.0:1
4.00” Stroker crank
Eagle I beams
Gen 2 Edelbrocks with bowl cleanup
Victor gasket matched at flange only
SS830 Quick Fuel
Crane Hyd roller 238/244@.050, 110lsa
HS 5016 roller rockers
91 pump gas
34* timing
Thanks.
Old Apr 22, 2021 | 03:31 PM
oldsmoboogie's Avatar
Love that torque curve! Do you have a guess what difference a Performer RPM intake would be?
Old Apr 22, 2021 | 04:08 PM
cutlassefi's Avatar
Yep it made more tq and over a longer range than that 455 I posted did, and it’ll idle at 850 no problem.
I’m not sure why people even fool with big blocks anymore. Plus good, useable 455 blocks are getting harder and harder to find not to mention more expensive.
And yes most likely about 10-15hp less with an RPM but I’d bet it would make 550tq.
Both the HP and tq peaks are low enough already that it really needs more intake volume and probably a bit more ex duration as well.
However it’ll be a fun drive for sure!!
Old Apr 22, 2021 | 04:18 PM
VORTECPRO's Avatar
Very nice! Can you post the fuel flow and BSFC?
Old Apr 22, 2021 | 05:43 PM
RetroRanger's Avatar
72 Olds CS
wow impressive torque and horsepower thanks for posting
Old Apr 22, 2021 | 08:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Another winner Mark!
Old Apr 22, 2021 | 08:57 PM
ijasond's Avatar
Purveyor of Polyurethane
I need me one of those...
Old Apr 23, 2021 | 03:33 AM
OLDSter Ralph's Avatar
Thats always a never ending debate.
Old Apr 23, 2021 | 05:57 PM
Mr Nick's Avatar
Regular gas block?
Gen 2 heads are not the newest offerings, correct?
Old Apr 23, 2021 | 08:43 PM
cutlassefi's Avatar
Originally Posted by Mr Nick
Regular gas block?
Yep and correct.😀
Old Apr 24, 2021 | 04:44 AM
Mr Nick's Avatar
How did it idle? Would you do a larger LSA if it was running EFI?
Old Apr 24, 2021 | 06:22 AM
cutlassefi's Avatar
Idled fine at 850-900. No I wouldn’t change it. If your EFI won’t compensate then I probably wouldn’t use it.
Old Apr 24, 2021 | 06:25 AM
VORTECPRO's Avatar
A 238 @ .050 hyd roller is a good sized cam in a 450 inch engine. Will require a decent converter to run hard. With the aftermarket crank at least you have a provision for a pilot bearing in a stick application.
Old Apr 24, 2021 | 08:06 AM
Mark, what was lift on that cam?
Old Apr 24, 2021 | 11:21 AM
cutlassefi's Avatar
mark, what was lift on that cam?
.587/.579
Old Apr 24, 2021 | 03:36 PM
ELY442's Avatar
Do you know what jets are in the SS830 Quick Fuel? Any jets or air bleed changes?
Old Apr 24, 2021 | 03:48 PM
cutlassefi's Avatar
Good question. Stock is 78/86 I believe with #28 hsb. Final combination was 83/91 with #31hsb’s. Idle bleeds were untouched although those could’ve gone up a few numbers as well.
My pet peave, Guys who throw on carbs, fiddle with the idle screws and say it’s tuned, amazing.
Old Apr 25, 2021 | 08:02 AM
Bernhard's Avatar
Nice build.
I agree the small block is the best bang for the dollar with the new stroker crank, rods, pistons, and heads.
What kind of gains would you expect from the new heads and ARH header upgrade?
Old Apr 25, 2021 | 10:50 AM
cutlassefi's Avatar
Originally Posted by Bernhard
Nice build.
Heads probably 10-15, headers less than 10. I did a 480 big block years ago that made 614 with Hooker Super Comps, 622 with ARH’s. They look great but won’t make a big difference in power, at least in my experience.
69Chrgr
Apr 24, 2021 07:50 AM
cutlassefi
Oct 21, 2017 02:59 PM
1970cs
Paint
Oct 13, 2014 09:01 PM
coppercutlass
Jul 8, 2013 07:56 PM
cutlassefi
Apr 18, 2013 05:27 AM
