Why do alum. heads .........?
Old August 28th, 2018, 07:48 PM
Gascoop's Avatar
I asked this question on another members thread about alum. heads but no one ponied up. So, from all the pics I've seen it looks like both Edelb. and Procomp heads stick out over both ends of the cyl. block by about 1/2" -3/4" ......... Why? Is it because they are in fact aluminum and just need a little extra meat for strength or what? My 455 didn't have heads on it, do the stockers stick out the same way? Thanks, Dave
Gascoop is offline
Old August 28th, 2018, 08:15 PM
Battenrunner's Avatar
The stock iron heads do not really hang over the block deck surfaces at all, except for the accessory bosses that stick out a bit from the rest of the head casting and the deck.
I think part of the reason why the Edelbrock heads are cast "wider" and hang out over the block deck surface is that they made the ends of the heads flat where the accessory bosses would have been compared to iron heads, instead being only threaded holes in the overly-thick ends of the heads. It is stronger to thread into a flat end of a large aluminum casting than a small boss that sticks up. The Procomp heads are pretty much a copy of the Edelbrocks from what I have seen/read.
The cast aluminum aftermarket heads for Olds engines will work fine with a Big Block and a mechanical fuel pump without any mods.
Hope this helps!
Battenrunner is offline
Old August 29th, 2018, 05:46 AM
cutlassefi's Avatar
You can’t use aluminum heads at all on a small block with a mechanical pump. You can’t grind enough away before you hit water.
cutlassefi is offline
Old August 29th, 2018, 06:28 AM
Thanks for coming in to correct that Mark, I removed my incorrect info about small blocks.
Old August 29th, 2018, 06:35 AM
oddball's Avatar
Betcha it's quicker/cheaper/easier to cast and machine the aluminum that way. The factory needed mechanical pumps to fit on small blocks. The aftermarket sure doesn't.
oddball is offline
Old August 29th, 2018, 06:40 AM
Inline's Avatar
Bad information. They have been grinded and welded shut. No sense for doing that, but done nonetheless.
Inline is offline
Old August 29th, 2018, 07:52 AM
cutlassefi's Avatar
You hit water though right? So I was right.
Old August 29th, 2018, 09:11 AM
Inline's Avatar
Cant use at all.
Is different than hitting water and welding it shut.
Inline is offline
Old August 29th, 2018, 10:31 AM
cutlassefi's Avatar
Cant use at all.
Sure.
Old August 29th, 2018, 07:57 PM
Gascoop's Avatar
Ok, thank you for answering my question............
Gascoop is offline
Old September 2nd, 2018, 08:28 AM
cjsdad's Avatar
Cant use at all.
I guess that right there explains the difference between "can't" and "shouldn't"!
cjsdad is offline
brownbomber77
April 9th, 2022 06:25 AM
steel-and-fire
December 4th, 2018 06:04 PM
6t7
June 18th, 2018 06:55 AM
marxjunk
July 30th, 2016 07:44 PM
Magna86
October 19th, 2013 08:53 AM
Quick Reply: Why do alum. heads .........?
