Big cam and A/C
Old July 30th, 2017, 02:40 PM
a70oldscutlass's Avatar
Big cam and A/C
I have a 350 with a jm 3-4 cam in it (230-238 522-542) and was going to run air on it for a trip coming up.I have 3;08 gears with a edge 3600 stall.Will it work?
a70oldscutlass is offline
Old August 3rd, 2017, 02:14 PM
Telecom Guru
jslabotsky's Avatar
Gear ratio sounds fine for running the compressor. What's your highway cruise RPM? The main thing, with that cam, will be having enough vacuum to run the vent actuators. If the air comes out the right vents when you're at cruising RPM, it will be fine. If your idle is lumpy you might have to raise the idle RPM a bit to keep it from stalling. Or you can manually turn off the A/C when sitting at a stoplight.
jslabotsky is offline
Old August 3rd, 2017, 04:26 PM
stevengerard's Avatar
I have Rhoad's lifters in my W30 as I have a bunch of vacuum operated accessories. They help - though next time around I'll probably go with a more modern cam design
stevengerard is offline
Old August 3rd, 2017, 07:52 PM
oldsmobiledave's Avatar
My 2 cents
Your drive line is poorly matched. That gear doesn't go with that cam and converter in my opinion.
oldsmobiledave is offline
Old August 4th, 2017, 08:55 AM
cutlassefi's Avatar
X2. No mention of compression ratio either.
cutlassefi is online now
Old August 11th, 2017, 03:30 AM
ph_ckstick1
midnightleadfoot's Avatar
You will have problems, that rear gear will have the rpm lower than the cam power-band, adding the load of a/c it will most likely fart, cough/etc
Don't expect it to idle, without stalling with the a/c on ,or you with one foot on gas and one on brake at lights..
I had a/c on a 355 with a 292 cam but I had 411 gears, and two idler pulleys to help keep the belt on..
midnightleadfoot is offline
Old August 18th, 2017, 09:01 PM
Firewalker's Avatar
He never mentioned the true diameter of his tires, or how far the trip is, or how fast he would be going. In fact too little info period.
Firewalker is offline
Old August 19th, 2017, 11:27 AM
Gary
VC455's Avatar
To solve the potential stalling problem, add the electric solenoid used to cut the throttle opening at shutoff on 70s Cutlass models.
If you power the solenoid from the air conditioning clutch relay, it will advance the throttle however much you want whenever you start the A/C. This will keep the engine from stalling and could even provide adequate vacuum to operate the diverter doors.
VC455 is offline
Old August 19th, 2017, 01:00 PM
Firewalker's Avatar
Those electric solenoids are handy for a lot things, when you get even more creative that just using them as anti dieseling devices when you kill the motor. Good idea you have, especially with him having that high of a converter stall.
Octania
April 7th, 2016 02:51 PM
Octania
July 10th, 2015 09:21 AM
Uncle Hulka
March 12th, 2014 03:41 PM
Scott Hamel
August 16th, 2013 07:46 AM
Kidcutty
March 10th, 2010 06:08 AM
Quick Reply: Big cam and A/C
