Wild Rides rear cross member
Old Jul 24, 2022 | 04:05 PM
gear head's Avatar
I bought this cross member a few months ago and am now getting it in the car. It's a fine piece and comes with chromoly upper bars. Everything went straight forward until the initial fit up, the frame rails are one inch wider than the cross member and I know my frame is in spec. No problem, I made a set of templates to box endplates on each side of the cross member. Time to get things cut and fit.
Old Jul 24, 2022 | 04:15 PM
fleming442's Avatar
Installing with the body on, too. Ballsy. I like it!
Old Jul 24, 2022 | 04:26 PM
Duh's Avatar
Duh
Wild Rides make really nice stuff. My roll bar from them fit like a glove. If you have issues reach out to them, excellent customer service
Old Jul 24, 2022 | 09:49 PM
Bernhard's Avatar
Nice.
That will stiffen up the back of the car nicely as well as give you infinite adjustment very cool piece.
Old Jul 25, 2022 | 04:33 AM
gear head's Avatar
Lol, why make it easy, some of these welds will be interesting...I'll probably invent a few new cus words in the process.
Old Jul 25, 2022 | 04:37 AM
gear head's Avatar
No doubt about that, Gene has been great to work with in the past, I have the lower a box mounts already installed and their ARB as well. I am going to give him a call today to let him know what I have found on the fitment.
Old Jul 25, 2022 | 04:40 AM
gear head's Avatar
Originally Posted by Bernhard
Nice.
For sure, between the adjustable lower and upper mounts, I shouldn't have much issue with putting IC where I need it.
Old Aug 7, 2022 | 04:19 PM
gear head's Avatar
Just a small update on this.... I contacted Wild Rides about the frame width discrepancy and their solution was the same as what I came up with. They also said there have been a few people call in about this issue. At this time I have all the bits cut, fit and tacked. I also have the chassis centerline plotted and a couple square lines to make sure the new crossmember goes in square. Time to get her glued in.
Old Aug 9, 2022 | 09:15 AM
83hurstguy's Avatar
That's some serious work - love it!! Looks like some nice parts.
Old Aug 28, 2022 | 04:59 PM
gear head's Avatar
I should put a period on this thread. The crossmember is fully welded in(welds look like ***, uphill with limited visibility has not been my strong point).
Here's my thoughts on this piece..
I don't think they make a good enough attempt to control distortion when they weld in the control arm brackets, mine was warped +/- 0.250". If I had welded it in using their instructions my pickup points would have been off from square about a 1/4". I squared the crossmember using the pickup points and was able to get them all within a 1/16". I have been in contact with wild rides and they are documenting end user experiences to better the product. All in all, I think it's a great product for the stock suspension guys, just pay attention when installing.
Tim75
Sep 4, 2020 07:23 PM
kencpless@gmail.com
Sep 4, 2020 05:05 PM
tkcutlass
Aug 3, 2020 08:28 PM
wills30
Jan 24, 2020 09:15 AM
rptw32
Jun 23, 2011 09:07 AM
